  • kworm
  • kworm
18 Jun 2025 15:15
Replied by kworm on topic QTPlasmac pierce delay handling
Category: Plasmac
I tried a resistor and no luck with the contact. I'll give Tommy's reed relay a try. Does it matter where it is in the lead and should it need a resistor?
18 Jun 2025 14:50
Replied by tommylight on topic How to jog when beyond soft limits
Category: EtherCAT
Yes, LinuxCNC supports backing off of the limits, be it hard or soft, it has a button for that in the GUI, but :
-you never mention any info about the machine, like it uses EtherCAT
-i have no experience with EtherCAT, so no idea if normal LinuxCNC stuff applies to it
-you keep asking for help, but still fail to provide info, this is frankly agonizing
-you posted twice in the wrong sections, there is EtherCAT section on this forum, but this is not important as we do not mind moving topics around, and i did this once, now i have to do this again as you did not provide the info on the first post, nor the second nor....
In general, limits should never be crossed if everything is set up properly, and that is easy to achieve, but this is EtherCAT, so i am moving this there, much more experienced users there so should figure where the issues is.
I would venture a guess at setting some small HOME_OFFSET in the ini file, like a mm or two, so even when you disable motors they could not reach limits. Maybe this is all you need...
  • kubes
  • kubes
18 Jun 2025 13:22 - 18 Jun 2025 14:12
Replied by kubes on topic How to jog when beyond soft limits
Category: EtherCAT
So you are saying that Linux CNC supports jogging back into soft limits?
config attached
  • Edi_48
  • Edi_48
18 Jun 2025 12:26
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
Hallo
Realtek DKMS-Treiber. installiert.
Test
60000 packets transmitted, 60000 received, 0% packet loss, time 60021ms
rtt min/avg/max/mdev = 0.085/0.161/3.281/0.042 ms
18 Jun 2025 12:04
Category: EtherCAT
Much better to post more info about your machine and how the homing is set up, and uploading config files usually helps a lot.
  • kubes
  • kubes
18 Jun 2025 11:44
Category: EtherCAT
I have absolute encoders and thus don’t home. Though through other posts it does not seem that is well supported.
I thought this would be a quick answer. Does Linux cnc not have the ability to jog to get back within soft limits? I would expect the that can’t jog more into the limit but you should be able to jog out of the limit. Is this supported?
  • TheRealMable
  • TheRealMable
18 Jun 2025 11:34
Replied by TheRealMable on topic MESA 7i76 - Lenze VFD: Where are the 10V
Category: Driver Boards
After some trial and error, I got it kind of working.
The wiring:
SPIN+ 9
SPINOUT 1U
SPIN- 7 and GND (you need to pass GND from your Field Power to 7 at the application I/O Modul)
ENA+ VField (+24V)
ENA- 28
DIR+ VField (+24V)
DIR- E4 (digital Input, reverses spindle direction if "HIGH")
cave: the application I/O has two Inputs labeled "7". They both need to be connected to GND (they are not connected internally, so you need to bridge them).
The only Problem I have left is the scaling. As far as I understand it works like this:
"hm2_7i92.0.7i76.0.0.spinout-minlim" is set to the minimum RPM I want to allow linuxcnc to pass to the VFD. In my case I set it at 6000 (any slower and the spindle tends to stall)
hm2_7i92.0.7i76.0.0.spinout-maxlim same as "minlim" but with maximum RPM. I set it at 24000, so everything above S24000 is ignored/capped at s24000
hm2_7i92.0.7i76.0.0.spinout-scalemax the theoretical RPM call, that would tell the MESA card to pass the full SPIN+ Voltage to SPOUT.
So I set it to (5,2/5)*24000 = 24960. That does not seem to work too accurate. If I plot the set Speed (via S... command) and the frequency at the VFD, I get something that I would call "good enough for my hobby", but "wrong" enough to question my understandig of "spinout-scalemax".
I will try to post the graph I get in a separate reply. Are my thoughts on the scaling correct that far, or is there an error in my settings?
  • esmurf
  • esmurf
18 Jun 2025 10:19
Replied by esmurf on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
Yes it works for me.
However right now, i do not yet have the actual machine ready, only the servos mounted next to each other on a piece of chipboard.
I can home and run the "demo" that comes with Axis Gui.
  • SwitchWitch
  • SwitchWitch
18 Jun 2025 09:53
Replied by SwitchWitch on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
Any progress so far? Did you manage to do internal homing cycles with the A6?
  • Jens23
  • Jens23
18 Jun 2025 08:02
Replied by Jens23 on topic Einbindung AX5000 und EL3104
Category: Deutsch
Oh man, ich habe gefühlt alles bei Beckhoff zu dem Umrichter durchgeklickt aber das habe ich irgendwie überspungen oder nicht gefunden, sonst hätte ich das wahrscheinlich alles direkt gelassen....
Ich kann bei dem chinesischen Händler alle möglichen Infos anfragen aber ob das genau das ist, was Beckhoff dann benötigt.. wird sich zeigen.
Es geht um diesen Motor: www.alibaba.com/product-detail/Jianken-J...e_1601044938540.html
PMSM, also permanent magnet synchronus motor
  • Hakan
  • Hakan
18 Jun 2025 07:52
Cumark Closed-Loop VFD with EtherCAT (non-CiA402) Configuration
Category: EtherCAT
For 06.05 I would use an online hex-to-bin converter. 882 hex becomes 100010000010 bin
so bit 1, 7 and 11 are set (0-based system), check the table page 59. You have asked for Start, Run Enable and Remote.
I looked around bit more. In the User manual you shared there is an example of how to start the drive from TwinCAT.
That's what you have followed and gave the strange behavior?
If that doesn't work, what can one do?
  • deedee
  • deedee
18 Jun 2025 07:43 - 18 Jun 2025 07:53
Replied by deedee on topic Einbindung AX5000 und EL3104
Category: Deutsch
Oha, das könnte spannend werden:
infosys.beckhoff.com/index.php?content=....d=SynchronmotorenBei Synchronmotoren können Sie nur einen bereits vorhandenen Motor auswählen, es ist nicht möglich, eigene Motoren zu erfassen. Sollte Ihr Motor nicht aufgeführt sein, wenden Sie sich bitte an unsere Supportabteilung.
Bist Du sicher, das es sich um einen Synchronmotor handelt? Hast Du einen Typ/Unterlagen zu dem Ding?
  • Jens23
  • Jens23
18 Jun 2025 07:14 - 18 Jun 2025 07:14
Category: Deutsch
Das ist ein chinesicher Synchronmotor mit 3,5kW, 800Hz und TTL Encoder. Soll als Frässpindel genutzt werden, die Positionierung soll dann für "rigid tapping", also Gewindeschneiden genutzt werden. Wenn auch nur kleine Gewinde, da eine 3,5kW Spindel nicht so wirklich viel Drehmoment hat.
Ich denke nicht, dass mir da jemand eine kompatible Datei geben kann. Frequenzumrichter mit Positionierungsfunktion sind nicht ganz so leicht zu bekommen. Der AX5106 war die beste Option für wenig Geld (gebraucht). Die Alternative wäre ein Metronix ARS2310 FS gewesen aber der kostet selbst gebraucht noch 1500€ und das ist mir wirklich zu viel.
  • deedee
  • deedee
18 Jun 2025 07:08
Category: Deutsch
Welchen Motor nutzt du?
Soweit ich mich erinnern kann, gibt es ja die Motordatenbank bei Beckhoff. Alternativ bietet evtl. der Motorenherstellen ja eine Beschreibungsdatei an.
  • Jens23
  • Jens23
18 Jun 2025 06:46
Category: Deutsch
Super, vielen Dank!
Ich gucke mal wie weit ich komme. Ich schätze mittlerweile, dass die Konfiguration in TwinCat die größte Hürde wird, da ich keinen Beckhoff Motor nutze.
Aber solche Herausforderungen können ja auch spaß machen
Displaying 1381 - 1395 out of 25076 results.
Time to create page: 0.228 seconds
