  • wusel0464
  • wusel0464
07 Nov 2025 16:14
Replied by wusel0464 on topic Touch Plate
Touch Plate
Category: Qtvcp
Hello,
I measure every tool after changing, this happens automatically. In principle, only an offset to the previous value is determined; I don't write anything into the tool table. That doesn't make sense to me either since I don't have an automatic tool changer.
Here's another link:
www.patreon.com/posts/29-linuxcnc-der-27282521?l=de
forum.linuxcnc.org/qtvcp/39423-qtdragon-...tool-change?start=30
Many greetings, Frank.
  • cmorley
  • cmorley
07 Nov 2025 16:10
Replied by cmorley on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
Do you want A to rotate around X?
if you load a tool and jog A is this what you see?
Can you test the simulated config?
  • clayton2ndtry
  • clayton2ndtry
07 Nov 2025 15:46
"file ./live/filesystem.squashfs failed the MDS checksum"
Category: Installing LinuxCNC
It appears the core problem is that 2.9 requires a 64 bit processor and my antique is a 686. I guess I will be staying in the past untilll I buy a new desktop.
  • ContinenteCNC
  • ContinenteCNC's Avatar
07 Nov 2025 15:44 - 07 Nov 2025 15:50
Replied by ContinenteCNC on topic New and Working RTAI debs for 2.9
So, is RTAI over?
I'm already feeling nostalgic.
How difficult will it be to use RTAI from now on (from LinuxCNC 2.9.5 onward)?
The most recent setup I’ve been able to get working is kernel 5.4.258 + LinuxCNC 2.9.4, using the following .deb packages (with isolcpus=3):
linuxcnc.org/dists/bookworm/base/binary-amd64/
linux-image-5.4.258-rtai-amd64_5.4.258-rtai-amd64-2_amd64.deb
linux-headers-5.4.258-rtai-amd64_5.4.258-rtai-amd64-2_amd64.deb
rtai-modules-5.4.258_5.3.3-linuxcnc-delta_amd64.deb
linuxcnc.org/dists/bookworm/2.9-rt/binary-amd64/
linuxcnc_2.9.4_amd64.deb
I was not able to get 5.4.290 + 2.9.4 working, nor 5.4.279 + 2.9.2. (I will post the error messages later.)
The 2.9.7 release notes state: "RTAI is still supported, but in the short term, building from source is likely to be the most expedient way to get 2.9.7 on that platform."
I’m wondering whether this is a reasonably straightforward process, or if it requires deeper OS-level debugging knowledge.
07 Nov 2025 15:14
Replied by tommylight on topic booten dauert lange 1min 30 sek , alles ok
Add # in front of the line starting with
UUID=63aa136.......
save and exit, then reboot.
07 Nov 2025 15:11
Replied by tommylight on topic realtime log position to txt use python script
LinuxCNC already has that feature, it is called POSITION_FILE and should be added to the ini file in the [TRAJ] section, something like this
POSITION_FILE = last_position.txt
  • PCW
  • PCW's Avatar
07 Nov 2025 14:33
Replied by PCW on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Category: Driver Boards
You can look at the .pin files in the firmware directory
to choose a appropriate pinout
7i92t_5abob_encd.bin for example has 5 stepgens and 6 encoders
Note that if you connect directly to encoders and motor drives:
1. The 7I92T I/O pins are like a bare parallel port pins and will be instantly damaged if connected to a voltage outside the -0.5 to +7V range. This is easy to do if system grounding is not 100% correct.
2. If you use bare 7I92T outputs to connect to step motor drives, they should be used in a a sinking configuration, as that is the only way to get full 5V drive:
DRIVE 7I92T
PUL+ +5V
PUL- 7I92 STEP PIN
DIR+ +5V
DIR- 7I92 DIR PIN
  • JT
  • JT's Avatar
07 Nov 2025 14:28
Flex GUI was created by JT
Flex GUI
Category: Flex GUI
What is Flex GUI?
It's a drag and drop GUI that requires no programming knowledge to build a GUI using the latest PyQt6.
Where are the Documents?
gnipsel.com/linuxcnc/flexgui/index.html
Where is the Flex GUI repository?
github.com/jethornton/flexgui
Where can I ask for feature requests or report a bug?
Here or on the repository github.com/jethornton/flexgui/issues or Libera.Chat channel #flex-dev
Are there any videos showing how to build a Flex GUI?
Version 1.3 www.youtube.com/playlist?list=PLzYeNVt90...b9GL6SDnoM1ItneA3s-K
Version 1.1 www.youtube.com/playlist?list=PLzYeNVt90...qACmFKau-nfGDKv-8WsD
Note: some items may have changed since doing these videos as we tested the snot out of Flex GUI
Version 1.0 www.youtube.com/playlist?list=PLzYeNVt90...FzJMaZwycZuHITzFxHgW
JT
  • fery15sty
  • fery15sty
07 Nov 2025 13:46 - 07 Nov 2025 13:49
Replied by fery15sty on topic realtime log position to txt use python script
Thanks for your help. But position-log.txt doesn't show up to record.
I'm using LinuxCNC 2.8.4 Debian Buster.
  • karlhe
  • karlhe
07 Nov 2025 13:34 - 07 Nov 2025 14:15
Replied by karlhe on topic booten dauert lange 1min 30 sek , alles ok
  Hallo tommy,ich habe sudo nano /etc/fstab ausgeführt und
das sieht dann so aus:
siehe Foto
der uuid  / ext4  errors=remoundas sollte der sein. der gelöscht werden kann?
karlhe
  • meister
  • meister
07 Nov 2025 12:49
        outfile.seek(0) # seek to start of file (keeps only one line in the file)
        outfile.write(" ".join(row))
        outfile.flush() # immediately write to disk / performance warning !!!
  • meister
  • meister
07 Nov 2025 12:43
better use python3
#!/usr/bin/env python3
import linuxcnc
import time
stat = linuxcnc.stat()
with open("position-log.txt", "w") as outfile:
    while True:
        stat.poll()
        row = []
        for n, axis in enumerate("XYZABCUVW"):
            stat.actual_position[n]
            row.append(f"{axis} {stat.actual_position[n]}")
            #print(f"{axis} {stat.actual_position[n]}")
            #outfile.write(f"{axis} {stat.actual_position[n]}\n")
        print(" ".join(row))
        outfile.write("\n")
        time.sleep(0.1)
  • FPVUALAB
  • FPVUALAB
07 Nov 2025 12:42
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Hello! Thank you for your support! I only use 7i91th.
  • fery15sty
  • fery15sty
07 Nov 2025 12:20 - 07 Nov 2025 12:29
Can someone help me create a Python script to record positions in the event of a power loss or LinuxCNC error?
I plan to create an external real-time position logger with an update interval of 0.001 seconds. I use this feature for a wirecut machine. I'm using a Python script and have tried activating log_position_to_txt.py with the M-code command, but the position logging process results in a code overflow, causing the .txt file to grow uncontrollably.
Here's the code for log_position_to_txt.py:
#!/usr/bin/env python2.7
import linuxcnc
import time
while True:
stat.poll()
x,y,z,a,b,c,u,v,w = stat.actual_position
outfile.write("X ")
outfile.write("{:.4f}\n".format(x))
outfile.write("Y ")
outfile.write("{:.4f}\n".format(y))
time.sleep(0.001)
Can someone help me fix my Python script so that... position recording does not result in code accumulation?
Displaying 11341 - 11355 out of 12835 results.
Time to create page: 3.607 seconds
