  • karlhe
  • karlhe
26 Oct 2025 16:21 - 26 Oct 2025 16:22
Replied by karlhe on topic linuxcnc bootet nicht mehr
Category: Deutsch
Hallo,
ich habe mit einem usb linuxcnc live den rechner gestartet.
dann linuxcnc damit neu installiert. mbr wurde auf der entsprechenden festplatte
neu installiert. nach fertigstellung, neu gestartet. mein Linuxcnc und die maschine laufen wieder.
  • Aciera
  • Aciera's Avatar
26 Oct 2025 16:09 - 26 Oct 2025 16:10
Replied by Aciera on topic MESA 7I92 programming
Category: Driver Boards
It opens a blank site but should download a .zip file (or open a popup about downloading a zip file with all the source files).
This is what I get when I click on the link in your last post:
  • TJ
  • TJ's Avatar
26 Oct 2025 15:58 - 26 Oct 2025 16:02
Replied by TJ on topic MESA 7I92 programming
A Mesa webáruházban, ha a támogatásra kattintok, csak egy üres ablakot hoz fel.
(www.mesanet.com/software/parallel/7i92.zip) vagy bármilyen más.
Csak a letölthető PDF.
Or is it just me that the download from the MESA site doesn't work?
Ezért kérdezem, hogy hol érhető el még a teljes kód.
  • heaven
  • heaven
26 Oct 2025 15:45
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Just a hal component to take data from the UART and encoder channel then handle it
  • boksi
  • boksi
26 Oct 2025 15:28
Okey, are you referring to make custom firmware/component for FPGA for UART + quadrature encoder logic or referring to hal component?
  • PCW
  • PCW's Avatar
26 Oct 2025 15:22
Replied by PCW on topic MESA 7I92 programming
You would need the Xilinx tool chain (Webpack 14.7)  for a 7I92, 7I92H, 7I92M
  • Aciera
  • Aciera's Avatar
26 Oct 2025 15:19
how to get rid of the probed dumping non-probe mode error?
@abs32
Please don't post the same questions in different threads.
  • TJ
  • TJ's Avatar
26 Oct 2025 15:13
CT identifies it as Mesa 7I92 and suggests corresponding files for upload.
I uploaded several files to it as a test. It works fine.
Test assembled on the table CNC program moves the motor + outputs and inputs work.
  • thanks for the help
26 Oct 2025 15:10
Replied by thanks for the help on topic Manual tool change + tool lengh touch off
I was wondering if any could give some insight on this one.  I tried to use the M6 subroutine that orangecat made.  I was able to get the probe working, change the ini and hal files accordingly.  I got to the point were the tool would probe, but my tool table won't populate with that number.  When I debug the 5063 in mdi I get ###### not an actual number, however the 5063 variable will show up in the var file in the config folder as a function of the 38.2 probing routine as an actual number.  I tried to debug other variables like 5181 which is the x position for the G30.1 command and although the var table in the config folder would populate with a number, when I debug the 5181 in mdi I still get #####.  I'm assuming the debug should yield the same number in the var file and not this symbol #####?  Which might be one of the reasons my tooltable is not populating?  I'm happy to provide any files, youtube videos, or anything else needed to help solve this problem.  I've learned a lot in the last month trying to solve this problem, any advice is much appreciated.
Thank you in advance.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 14:55
Are you really using 2.8.4 rather than 2.9.4?
This problem was fixed in 2.9.5. Do you have a good reason not to update?
(rather than 2.9.5 you should probably use 2.9.7. See:
forum.linuxcnc.org/21-axis/57364-axis-co...-9-6?start=10#336658 )
  • PCW
  • PCW's Avatar
26 Oct 2025 14:54 - 26 Oct 2025 14:55
Replied by PCW on topic Mesa7i96s and Postep60-250?
Yep, consider that when static, a 5A stepmotor may only drop 3 VDC so ~15W.
So with a 48V driver, only about 400 mA at 48V is needed to get 5A at the motor.
26 Oct 2025 14:39
Replied by tommylight on topic Mesa7i96s and Postep60-250?
Think of it as a buck converter...
  • PCW
  • PCW's Avatar
26 Oct 2025 14:33 - 26 Oct 2025 15:10
First, it's still not clear whether you have a 7I92 or 7I92T(x)
The support software zip file that has all the sources and project files
needed to build firmware files is downloadable from Mesa's webstore
(in the specification tab for the appropriate card)
26 Oct 2025 14:29
Replied by tommylight on topic MESA 7I92 programming
First, make sure what 7i92 you have, there is 7i92/7i92M/etc, then there is 7i92T/7i92TM/etc, meaning with T and without T, they have the same functionality, but use different FPGA so flashing the wrong firmware is not good.
They always have a sticker on the back with the model written.
26 Oct 2025 14:25
Replied by tommylight on topic Workshop update
Workshop update
Category: Show Your Stuff
Young??? I am 55! :)
And the dog got banned from the shop for a while as i got tired of monitoring her so she does not pee at everything! :)
Displaying 12046 - 12060 out of 12866 results.
Time to create page: 0.736 seconds
