  • cmorley
  • cmorley
04 Jan 2025 01:44
Replied by cmorley on topic qtdragon additonal buttons
Category: Qtvcp
The screen shown is a modded qtdragon_hd so requires a larger monitor.
I can't find the original topic on the forum here, but I do have a copy of the .ui file
You would put this file in YOUR_CONFIG_FOLDER/qtvcp/screens/qtdragon_hd/qtdragon_hd.ui
  • ccatlett1984
  • ccatlett1984
04 Jan 2025 01:36 - 04 Jan 2025 01:51
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
Category: Driver Boards
If you can reliably access the card on the RPI4, you would
sudo mesaflash --device 7c80 --spi --addr /dev/spidev0.0 --write 7c80d.bit
sudo mesaflash --device 7c80 --spi --addr /dev/spidev0.0 --write 7c80fall.bit --fallback
(7c80d.bit and 7c80fall.bit are in the 7c80.zip file in /configs/hostmot2/)
the zip file is available from the store in the card specification tab
From Pi4, dump of mesaflash BEFORE flashing: pastebin.com/kf8iUXQY
dump of mesaflash AFTER flashing: pastebin.com/5xm8FHpq
I forced a --reload in between each flash cmd, to validate the card took the firmware before moving on.
If this looks correct, I will proceed to swapping the pi5 back into the machine.
Update: Post flashing, with the Pi5 - halcmd sees the card.
pi@linuxcnc:/$ sudo mesaflash --device 7c80 --addr /dev/spidev0.0 --spi --readhmid [sudo] password for pi: open: No such file or directory No 7C80 board found
in /dev/ only a single spi entry exists "spidev10.0"
running mesaflash (using the above spi entry) results in the following
pi@linuxcnc:/$ sudo mesaflash --device 7c80 --addr /dev/spidev10.0 --spi --readhmid
Unexpected cookie at 0100..0110:
ffffffff ffffffff ffffffff
No 7C80 board found
pi@linuxcnc:/$
04 Jan 2025 01:28
Replied by Cant do this anymore bye all on topic Arduino IO Expansion
Category: Show Your Stuff
Yep have the hardware.
Nope doesn't work the way you propose.
Tried with a 500mm cable between my RPi5 and a 7c81 board, SPI fails even below the rates for a USB to arduino serial connection. In actual fact even having a grounded conductor between each SPI signal and trying to send signals from one pcb to another is not reliable over a distance of about 75mm.
From experience high speed serial communications, RS-422, SATA or whatever you want to try requires differential signalling, which causes timing issues with SPI. I researched this about 12 months ago.
  • ccatlett1984
  • ccatlett1984
04 Jan 2025 01:12
  • Ehsan_R
  • Ehsan_R
04 Jan 2025 00:35
Replied by Ehsan_R on topic Arduino IO Expansion
I still believe that spi can be used instead of serial communication and have a real time component.
If possible, have someone with the necessary hardware try this and report back
Many thanks
  • PCW
  • PCW's Avatar
04 Jan 2025 00:30 - 04 Jan 2025 00:31
  • ccatlett1984
  • ccatlett1984
04 Jan 2025 00:24
You should be able to with the latest mesaflash
alright, putting the pi4 back in, let me know what needs done.
  • PCW
  • PCW's Avatar
04 Jan 2025 00:20
  • ccatlett1984
  • ccatlett1984
04 Jan 2025 00:19 - 04 Jan 2025 00:21
I apologize, this is my fault, some production 7C80 cards ended up with
the wrong firmware. We can issue you a RMA for reflashing the card with
correct firmware. Sorry for the inconvenience.
So, since i have a pi4 that can see the card, is it possible for me to flash the correct firmware?
I'd much rather not kill a week plus in cross shipping.
I'd like to try it here if it doesn't require super-specialized equipment, I've made JTAG cables before.
  • PCW
  • PCW's Avatar
04 Jan 2025 00:18
Mesaflash 7i96S - Error at 0x10004B expected: 0xA but read: 0x16
You can download the support software from Mesa's web store
(specification tab)
  • PCW
  • PCW's Avatar
04 Jan 2025 00:16
04 Jan 2025 00:16
Replied by Cant do this anymore bye all on topic Pi5 MESA 7c80: mesaflash can't see the card.
OK the original attempts were with the official raspbian image. The supplied kernel is not one suitable for Realtime in the way Linuxcnc requires a realtime kernel. There was discussion a few months ago reagrding real time being included in the mainline Linux kernels. When building a real time kernel there are 3 options from memory, if you do not choose the correct type it is not what Linuxcnc expects.
It would depend whether the kernel was pinned (excluded from updates or not) but on further reflection the Raspbian kernel is different to the mainline debian kernel for arm boards.
And honestly when you do an update you should have a look at what is being updated. before proceding.
With the Linuxcnc image did you enable the SPI interfaces in config.txt ?
If you had of clearly stated at the beginning you were using a raspbian image to begin with it would have made life a whole lot easier. It would have been suggested to use the Linuxcnc image from the get go.
  • poesel
  • poesel
04 Jan 2025 00:12
Just went back on this, you asked mesaflash to verify is the board has the pwm version and it does not, hence the result.
You would need to flash the board first with the firmware you need, and the files are on the Mesa web page
www.mesanet.com/software/parallel/7i96s.zip
Ah, sorry, my bad. I misinterpreted the options. Exchanged 'verify' with 'write' and it worked like a charm.
Correct version:
mesaflash --addr 192.168.1.121 --device ETHER --write 7i96s_2pwmd.bin
Also, thanks for pointing the location of the support package out. This website looks like they went bust 20 years ago...
  • cmorley
  • cmorley
04 Jan 2025 00:07
QtDragon PROBE: understanding popup error message
Category: Qtvcp
It might have been nicer if the max travel was calculated based on the length to probe.
ie probe length = 10, max _over_ travel = 5 then anything that moved 15 would trip.
04 Jan 2025 00:04
Yeah Tommy is pretty much correct in the fact that 1.5Mbaud does not equal 1.5Mbit because there are wasted bits.....start, stop, parity, address, etc
That will affect the overall byte rate, not the overall bit rate. If fact Tommy's definition made no mention of of protocols, which stop-start-parity etc would be part of.
When designing hardware for the transmission of serial data any control bits or bytes don't come into the equation.
Displaying 20836 - 20850 out of 21685 results.
Time to create page: 0.426 seconds
