qtdragon additonal buttons
- jyeomans
14 Dec 2024 04:08 #316622
by jyeomans
qtdragon additonal buttons was created by jyeomans
Hello
i have been using qt dragon HD and like it.
i would like to add some buttons to my screen and was looking for the directions or a resourct to help me.
i have three things i want to add.
i have a work light
a spindle light
and a relay that switches between my prob in put and my tool setter. both the tool setter and probe are normaly closed. seamed like the best way to do it.
i could put them on a tab or in utilitys. but still a littel unclear on how to do that.
thanks for the help.
i have a work light
a spindle light
- Thank you received: 2181
14 Dec 2024 23:58 #316680
Replied by cmorley on topic qtdragon additonal buttons
The following user(s) said Thank You: tommylight, besriworld, Muftijaja
- jyeomans
15 Dec 2024 21:30 #316715
by jyeomans
Replied by jyeomans on topic qtdragon additonal buttons
I wanted to make my own user tab for them. But I’m unclear how to do that, and I’m unsure whether you can use a user tab well while the machine is running in auto. I haven’t tried yet.
I was going to add them to the user buttons. But I’ve used up most of them at this point.
Down the road, I also want to learn some other things. I’m adding pneumatics to my CNC to run some hold-downs, as well as an air blast.
I had the idea to add a pressure gauge to the system so I could set the machine to pause if there was a loss in air pressure, assuming that would cause me to lose a hold-down.
17 Dec 2024 02:38 #316829
Did you see this:
linuxcnc.org/docs/devel/html/gui/qtvcp.h..._sheet_custom_screen
Panels are mostly the same process.
Chris
Chris
- jyeomans
17 Dec 2024 15:25 #316869
by jyeomans
No i dont think i saw this page. i saw one simular but i don't rember seeing the Build A Simple Clean-sheet Custom Screen
thanks i will have a read through it.
18 Dec 2024 05:00 #316906
It's pretty skimpy on detail. Ask questions here and I'll try to help and maybe add docs for next time.
- Muftijaja
- Thank you received: 4
02 Jan 2025 21:04 #317883
by Muftijaja
Replied by Muftijaja on topic qtdragon additonal buttons
cmorley, that screen looks very good! Would you share this with me? How can i install it, I am running that normal QTDragon for a while and was missing some of the buttons integrated here.
Thanks in advance!
Thanks in advance!
04 Jan 2025 01:44 #318004
The screen shown is a modded qtdragon_hd so requires a larger monitor.
I can't find the original topic on the forum here, but I do have a copy of the .ui file
You would put this file in YOUR_CONFIG_FOLDER/qtvcp/screens/qtdragon_hd/qtdragon_hd.ui
The following user(s) said Thank You: Muftijaja
- Muftijaja
04 Jan 2025 12:49 #318058
by Muftijaja
Thanks very much, cmorley! I will check it out asap.
- Mr. Mass
- Thank you received: 51
25 Jan 2025 08:42 #319806
by Mr. Mass
Replied by Mr. Mass on topic qtdragon additonal buttons
Tried to install this modified screenset but got a lot of errors. If I understand correctly here I need a modified handler.py file too?
Time to create page: 0.380 seconds
