  • TooTall18T
  • TooTall18T's Avatar
03 Jan 2025 18:24
Replied by TooTall18T on topic Linux CNC startet nicht mehr
Category: Deutsch
Was die Latenz angeht, hilft dir evtl. auch das Video:
  • resmond
  • resmond
03 Jan 2025 18:06
Replied by resmond on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
Now that I have my Pi 5 / Mesa 7i95T basically working (still re-reading Docs and tweaking ini/hal configs) I do like it and don't regret starting with it.
I faced the most challenges from the following:
  • Very rusty on Linux distro's, package managers and Kernel versions
  • The Docs, Form and Wiki are AWESOME but it's often a challenge to remember where something was documents to find and re-read the details once I hit a problem.  (Fortunately Google search will usually find Forum threads for error outputs.
  • Since the Pi4/5 are ARM based its more challenging to find Deb packages and APT sources for certain things.
  • I always started with the LinuxCNC Debian imaging for all my builds - then would screw it up from there.
I am planning to build up an Intel platform machine next to smooth out some of the ARM related challenges.  If I had it to do over I would have chosen Intel.
Here are a few of the options I'm looking at and I've used other boards for other projects.
LattePanda Mu ($105 on sale)
    A Micro x86 Compute Module (N100 CPU,8GB RAM,64GB eMMC)
     On DfRobot
Lite Carrier Board for LattePanda Mu Compute Module ($39)
(USB 3.0, Ethernet, PCIe 3.0, M.2 M key, HDMI)
     On DfRobot
The carrier has two PCIe slots (1x/3x) but most people will need to add wifi Intel M.2 Wifi ($19)
     On Amazon
So that's around $170 plus shipping then you have to choose a DC supply and this one is really fast if that matters.
LattePanda 2 Delta 432
A Pocket-sized Powerful Windows/Linux Single Board Computer (4GB RAM/32GB eMMC)
     On DfRobot
M.2 PCIe card riser ($30)  On Amazon
This one comes with WiFi so it just needs power. It has less memory than the Mu and needs the riser to plug in full sized PCIe cards but it comes with a fan.
LattePanda V1 (~160 on sale) On DfRobot
The Smallest Windows 10 Single Board Computer (Unactivated, 4GB/64GB)
Both the V1 and Delta 432 come with a built in Arduino with standard HAT connections but since this one does not have a PCIe compatible M.2 using PCI Mesa cards would be out. It would be Ethernet only.
I think it would be facinating to see what the built in Arduino might make possible for controlling odds and ends using the HAT boards.
03 Jan 2025 17:39
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Also sometimes users want something that doesn’t work within Linuxcnc’s model.
Mostly this will boil down to USB motion cards, usually ones the Mach supports and using Linuxcnc to send gcode to an external board. Most are accepting this is not supported and not in the pipe line, once every often someone will spit the dummy and throw all their toys out of the pram.
For other support channels you may want to jump over to the Linuxcnc homepage and see what the other options are and links to said options.
  • ihavenofish
  • ihavenofish
03 Jan 2025 17:35
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
Shiny!
03 Jan 2025 17:30
Replied by Cant do this anymore bye all on topic Arduino IO Expansion
Category: Show Your Stuff
Oh yeah, it’s a slave device, it doesn’t act as a master.
I doubt a higher rate interface would be a great advantage for a control panel.
I would assume the driver code would called within the context of the servo thread, about 1ms, to denounce a switch would require a couple of ms.
If you need a high speed reliable device to communicate with a control a Mesa card using a smart serial daughter card would be the go, operates at 2.5M bits per second over a Cat5 cable using differential signals and 5v can be sent down the cable as well.
  • johnbl
  • johnbl
03 Jan 2025 17:12 - 03 Jan 2025 17:14
Replied by johnbl on topic PathPilot V2 source code
Category: PathPilot
Grotius,
Can you please share the PathPilot source code? On GitHub or anywhere else?
I've already sent 2 cheques to Tormach to receive the sources. They gave me 2 different addresses so far, both were invalid and the mail bounced.
03 Jan 2025 17:01
Oh I forgot, development is very centralised via github. It’s a very mature project which can trace things back to a NIST proposal quite a few years ago.
03 Jan 2025 16:58
Any issues related to the Linuxcnc code is well reported thru the github channels.
Lists and the like on the forum don’t really work as, I mentioned before, users think that their problem is unique to themselves.
We started a thread a while back to gather issues related to Parallel Port cards. Every so often within a month 3 to 4 users will start a new thread with the same issues.
Apart from not having a SPI driver for the RPi5, due to the RP1 chip (which caused issues for many utilities in general use for accessing gpio on the RPi 4 and below) there is no real issue.
There was a big push at the end of 2023 to update the existing RPi images and create one for the RPi5, Rod worked hard on that and bounced a few ideas around with myself. Now it’s at a stage where it is quite mature and very usable. The only real “issue” is that the RPi imager utility cant be used with it for reasons discussed in this thread with the solution.
So far the hm2_spix driver works quite well and the gent who wrote it made some code changes to the original hm2_rpspi driver.
Once new packages are built I’m sure the RPI5 will be fully supported “out of the box” for it does require building Linuxcnc from the current code base for either the master branch or the 2.9 branch. Not a difficult task if one follows the instructions as set out in the docs.
Every cnc machine is different so one can not hope to have a plug and play solution unless one buys a cnc machine that has been preconfigured by the manufacturer.
There are many boards available from Mesa that people use for a variety of applications. On top of that there are a number or alternative projects Remora and Linuxcnc-RIO are just 2.
Myself I’ve taken a different path by using a Spartan 6 dev board, designing some boards that take care of level shifting and built firmware to suit using the Mesa sources, for some of the firmware I’ve tweaked the existing drivers to suit the IO config. Using the same hardware I can also use firmware from the Linuxcnc-RIO project.
There’s a lot of choice available.
  • PCW
  • PCW's Avatar
03 Jan 2025 16:48
Replied by PCW on topic Netzwerk abbruch
Netzwerk abbruch
What specific message does LinuxCNC print when starting?
(launch LinuxCNC from a terminal to get the start up messages)
  • Hobbymate
  • Hobbymate
03 Jan 2025 16:33
Replied by Hobbymate on topic LinuxCNC 2.9 vs. 2.8 Using A-Axis for ATT
Category: Turning
Hi. How to change code to work without index and position signal. Like Boxford type turret driven on stepper motor. New in LinuxCNC.
03 Jan 2025 16:29
Replied by tommylight on topic Netzwerk abbruch
Netzwerk abbruch
Starte ich eine Maschine bekomme ich eine Meldung das kein Netzwerk habe , Ping keine antword.
Wenn ich Netzwerk neu starte habe ich wieder einen Ping.
Seems like wiring/EMI issue.
How is the Mesa board powered ?
03 Jan 2025 16:29
No it’s not a SPI to Ethernet converter.
It’s a chip that has an SPI interface and implements a, for lack of a better description, a network stack.
A micro controller connected to it still has to setup network related things, monitor it for received data and other such tasks.
So no it does nothing to increase the distance between SPI devices.
I suggest you go to the wiznet site and learn what that device actually does. From memory they use the 5500 device.
  • TomAlborough
  • TomAlborough's Avatar
03 Jan 2025 16:26
Replied by TomAlborough on topic LinuxCNC on Raspberry Pi 5
Hello tommylight,
That Google excerpt could be way off. I don't know. The only way to know what the current state of (LinuxCNC/Pi 5) is to poll it users and those attempting to use it. As you say they may have a working system and be doing something else.
Your comment about "Set it once and never again" is true for a lot of software until you change something (like a controller or the software itself).
I know newbies don't read things. For me "usability" includes reducing the need to read stuff as much as possible.
A issue list/process has several attributes besides being a pain in the neck. One is to track issues that surface and ensure that the issue is fixed and available for download. Another is for the developers to assess how to improve the user's encounter with the hardware and software itself.
I offered to help. If there is no issue list (for PI 5 for now) maybe I could help to create one. It would help centralize some aspects of the development work. Also, people age out. It may allow the current crop of wizards help the next generation of users.
Thanks,
Tom
03 Jan 2025 16:18
Agree with Tommy.
Users skipping steps.
Users not typing in commands properly.
Users not relaying requested information.
Users blaming Linuxcnc when it’s a mechanical issue.
Users blaming Linuxcnc when it’s an electrical issue.
Users not bothering to look at the docs.
Cases of users editing config files with a word processor program.
Users not understanding the prepared Linuxcnc images are not meant to be a general purpose OS.
Users believing the fear mongers who will say you need to be a programmer.
Users thinking they are the first and only ones to have a particular issue.
Users who don’t know how to form a proper question.
The effing “Maker Community” that tells poor saps that a CNC machine is easy to use by anyone.
People that wear gloves near rotating machinery.
People that insist on soldering crimped connectors.
Ah fuck it just people in general.
  • Edi_48
  • Edi_48
03 Jan 2025 15:47
Replied by Edi_48 on topic Netzwerk abbruch
Netzwerk abbruch
Meine Dateien
Displaying 20881 - 20895 out of 21683 results.
Time to create page: 1.097 seconds
