  • Wischi
  • Wischi
02 Jan 2025 12:29 - 02 Jan 2025 21:18
Change color of SpeedControl widget using css
Category: Gmoccapy
Hello,
i am trying to change the color of the SpeedControl widget using css. It is used as the slider for feed/spindle override, the default color is orange. But I can't find out how to call it in css. I have the .css file set in the config ini and it is working if I change for example the color of labels or buttons.
This is what i tried:
speedcontrol {
     color: #9498A0;
Also i tried spc_rapid and spc_feed instead of speedcontrol. No effect. How to call it correctly? Thanks
  • Aciera
  • Aciera's Avatar
02 Jan 2025 11:53
Replied by Aciera on topic Lathe sub spindle m codes
Category: Turning
You can control multiple spindles using 'M3 $n'
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m3-m4-m5
  • RNJFAB
  • RNJFAB
02 Jan 2025 11:38 - 11 Jan 2025 00:31
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Category: Show Your Stuff
So after a few battles, i finally have the mesa board talking to LinuxCNC. I have movement. I have proximity sensors all connected and working. I have coded HAL to get the right distance traveled.
Still to go - laser pointer, z axis, air scribe, water table & tank, paint, clean out shed, concrete for shed floor to hold it.
I still have a glitch in the screen that shows what is being cut, and i get no preview of what i load,
  • epineh
  • epineh
02 Jan 2025 10:06
OK so to answer my own previous question basically I'm stupid, I hadn't set ownership to my user account, so Linuxcnc couldn't write to the var file, and most likely create it in the first place, which is why it was missing.
I had thought I'd done it but obviously I hadn't or maybe did a typo at the time. I followed the Docker install instructions as per the wiki instructions if anybody else is having the same issue.
Big thanks to Meister for creating this and thanks to everybody else supporting.
Russell.
  • timo
  • timo
02 Jan 2025 09:26
Replied by timo on topic Chasing Threads and Re-Threading
Never came across an M17 bolt (but M17x1 and M17x1.5 taps are available) :-)
Is the hex of the head 17 mm?
In that case it would probably be an M10 bolt as smc.collings already guessed.
M10x1 is common on rear axles for bicycle hubs, so that would be easy to confirm, by screwing the bolt into a nut from a bicycle.
Taps for it are "findable" e.g. Yamawa, Gühring, SUS, Corai, Regal come to mind.
Should it be M10x1 I would probably just make two slots into a hardenend bicycle axle with the angle grinder, then carefully screw it in with some cutting oil to clean up the thread.
  • gekonko
  • gekonko's Avatar
02 Jan 2025 07:50
Replied by gekonko on topic Cut Recovery Not Consistently Triggering
Category: Plasmac
My system is basically :
- installed from linuxcnc usb stick
- removed linuxcnc using synaptic
- installed RIP linuxcnc using documentation.
My locale is SK (Slovak)
i will try to install RIP in new, EN locale.
  • ihavenofish
  • ihavenofish
02 Jan 2025 06:55 - 02 Jan 2025 15:32
Replied by ihavenofish on topic Mini wannabe datron build
Category: CNC Machines
ATC action! :P
Should have animated the eyes. Oh well, next time.
  • cmorley
  • cmorley
02 Jan 2025 06:33 - 02 Jan 2025 06:34
assignments glitching with larger ladder programs
Category: ClassicLadder
No smoking gun yet, but it seems master branch will not load your program properly - and showed other bugs in master CL.
I do see your program uses 150 arithmetic expressions, which is the max you have available.
I got a sample program to use jump coils - see example.
(clicking the %B0 in the Vars bit window will change the #QW0 output from 1 to 5)
  • RNJFAB
  • RNJFAB
02 Jan 2025 05:58 - 02 Jan 2025 07:57
OK.
Wasn't sure about a real time kernal, so check and have "6.1.0-28-rt-amd64".
Have uninstalled all traces of LinuxCNC, and now using the synaptic package manager, have loaded the latest linuxcnc versions.
Start up pnfcof with the mesa 7i96, everything worked.
Still having the same issue. estop is red, cant be unclicked.
Cant select power. left hand side of the screen is blank/glitchy.
Any ideas??
  • PCW
  • PCW's Avatar
02 Jan 2025 04:35
Pi5 MESA 7c80: mesaflash can't see the card.
Category: Driver Boards
Note: Using POSIX non-realtime
Means it's not real time
  • phillc54
  • phillc54's Avatar
02 Jan 2025 03:54
Replied by phillc54 on topic Cut Recovery Not Consistently Triggering
Category: Plasmac
I don't see this issue on a current RIP build.
Are you by chance using a Wayland desktop and/or a non English locale?
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 03:46
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
Correct, they are visible under /dev/
  • ccatlett1984
  • ccatlett1984
02 Jan 2025 03:45
It is PREEMPT_RT
enabled RT when building.
02 Jan 2025 03:33
Replied by Cant do this anymore bye all on topic Pi5 MESA 7c80: mesaflash can't see the card.
With regards to the RPi5 images Rodw linked to a new one on his google drive that seems to fix the screen issues. This is the one I used recently with my RPi5.
Displaying 20956 - 20970 out of 21689 results.
Time to create page: 0.458 seconds
