  • Routerworks
  • Routerworks
11 Apr 2026 14:15
Replied by Routerworks on topic Need help setting up XYYZA for stepper motors
Category: Basic Configuration
I rather suspected that was the correct way to do it. I'll work on it.
thanks for you help.
  • grandixximo
  • grandixximo's Avatar
11 Apr 2026 14:04
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
github.com/LinuxCNC/linuxcnc/actions/runs/24246961815?pr=3807
new build has slight speed improvement, still working on it
  • devils4ever
  • devils4ever
11 Apr 2026 10:50
Replied by devils4ever on topic iMach3 P2-S Stops Working
I've never experienced the lag/delay you described. My setup seems to respond instantly to the pendant.
I guess I'll give the ferrites a shot.
  • grandixximo
11 Apr 2026 09:44
I know TP2 does not support G33.1 yet, I thought TP1 did but never tested, might have to do some work there, thanks for reporting, will try to patch it up soon
  • adhamamer
  • adhamamer
11 Apr 2026 04:29
Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
Category: Driver Boards
I measured again
from +5V to DIR+ = 5.13V and drops to exactly 5V when jogging in the negative direction
from +5V to DIR- is always at 0V That's for all channels on TB2 1, 2 and 3
Do you think i got a faulty board, Sorry this is getting so frustrating
  • PCW
  • PCW's Avatar
11 Apr 2026 04:16
The signals are differential but can be used single ended
That is DIR+ and DIR- should both change voltage when
the direction changes but one should change from 0 to 5V and the
other from 5V to 0 (relative to ground)
Measured differentially, you should always measure either
+5V or -5V across the DIR+,DIR- or STEP+,STEP- pins.
  • rodw
  • rodw's Avatar
11 Apr 2026 03:54
Replied by rodw on topic iMach3 P2-S Stops Working
I consider any of the Mesa SmartSerial boards to be 'direct I/O' as that method of connection is rock-solid and there's no human-perceptible lag or latency.  Which means a hand-held MPG with a 7i73 inside (for the digital display) will be be just as responsive as the panel-mounted stuff I built.
Well there are wireless pendants that wire into direct I/O (but they are not USB) that will give equivalent response
www.wixhctech.com/product/23.html
They use a lot of I/O but you can get versions that use digital inputs (which I have used) that save a few inputs
  • adhamamer
  • adhamamer
11 Apr 2026 03:00
  • spumco
  • spumco
11 Apr 2026 01:29
Replied by spumco on topic iMach3 P2-S Stops Working
Thanks for your input. That makes sense. Is it worth trying some ferrites?
Are there other brands/models that are more reliable and easy to configure with LinuxCNC?
Clip-on ferrites are cheap on Amazon if you want to try it.
Is it worth trying?  Up to you.  I got fed up with the iMach even when it was working.  Because it uses USB - and possibly because of how it's programmed - there is a delay between when you stop moving the wheel and when the machine stops.  If you move the wheel fast back and forth, you can get to the point where the machine is moving opposite to the wheel direction.  Totally unsafe.
I got used to industrial machines with "direct" I/O MPG's and control buttons.  On those machines, there is zero perceptible delay between control input and machine response - even to the point where big machines will jump and jerk trying to keep up with aggressive commands.  Having experienced that, it's like the difference between driving an F1 car and a 1970's Oldmobile with worn-out suspension, spongy brakes, and a sloppy throttle cable.
My personal preference is a standard A/B quadrature encoder, connected directly to Mesa inputs. All critical controls (cyc start/stop feed hold, RRO/FRO/SRO, continuous jog buttons, etc) are also direct inputs.  No microprocessor, no cool features, no wireless/wifi.
I have no experience with ethercat (native ethercat device or using a drive's I/O as GPIO), or any of the countless other clever methods folks have devised to expand IO by offloading through a USB or other bus of some sort.
  • rodw
  • rodw's Avatar
10 Apr 2026 22:56
Just take you XYYZ config and modify it by adding an extra joint and XYYZA
At this stage, you need to leave pncconfig or stepconf behind and work directly with your hal and ini
  • PCW
  • PCW's Avatar
10 Apr 2026 19:35
Is it possible that you have the incorrect step mode chosen in your hal file?
(step/dir is mode 0)
  • devils4ever
  • devils4ever
10 Apr 2026 19:15
  • Routerworks
  • Routerworks
10 Apr 2026 18:50
My Dual Y 3 axis works fine.  I am trying to setup a 4th rotary axis.  I used the setup wizard for steppers.  I doesn't have a XYYZA  option, only XYZA.
i attached the Y step and direction output to two outputs that appear to drive both Y motors on the Halscope. However without having a Y0 and Y1 as in the 3 axis setup I am hesitant to try driving the steppers as I am not sure they will both act in the same direction.  Looking at the 3 axis setup I would need 5 joints (0.0.0.0.0) to do this.
Would greatly appreciate some insight.
Thanks in advance
  • spumco
  • spumco
10 Apr 2026 18:40
I have a P4-S I abandoned a while ago due to flakey behavior and annoying USB lag/latency.  Solid, feels great, nice features... but unreliable for me.
I believe they are very sensitive to RF or EMI through the USB connection.  I've read a number of reports of similar issues - random resets.  One thread I read (maybe not on this board, cant remember) indicated the user could brick his iMach at will by stepping on a rubber anti-fatigue mat while holding the MPG.
When I had mine apart I realized the USB cable shield isn't connected to anything inside the MPG housing.  Not to the pcb ground, not to the case - just clipped short.  No way to dissipate static or anything inside (or outside) the MPG.  I'm not an electronics guru, but this didn't seem right.
If you are in love with it and don't feel like dealing with intermittent customer service from iMach, maybe add more ferrites to the cable.
Also - maybe - see if you can connect the cable shield to something that isn't powered on the PCB or housing.  And cross your fingers.
Displaying 3751 - 3765 out of 13582 results.
Time to create page: 0.251 seconds
