Add a rotary axis B on a lathe
- jean-claude
26 Aug 2020 09:17 #179546
by jean-claude
Add a rotary axis B on a lathe was created by jean-claude
Hello to all,
Is it possible to add a B rotary axis on a lathe (I think the axes would be XZC) and configure a post-processor in fusion360?
Thank you for your help
- Thank you received: 2177
26 Aug 2020 09:39 #179549
Replied by Aciera on topic Add a rotary axis B on a lathe
I guess it kind of depends what that B axis actually does. How would that axis interact with the XZ and or the spindle?
- jean-claude
26 Aug 2020 10:03 #179551
by jean-claude
Replied by jean-claude on topic Add a rotary axis B on a lathe
The spindle will be on the B axis.
- jean-claude
26 Aug 2020 10:44 - 26 Aug 2020 10:45 #179555
by jean-claude
Last edit: 26 Aug 2020 10:45 by jean-claude.
26 Aug 2020 13:06 - 26 Aug 2020 13:09 #179561
So is C a spindle and an axis as in a lathe with a spindle that can be positioned or is the B the only spindle and the C just a rotary axis? To me this looks more like a 4 axis XYZA milling setup with a rotary axis A and without the linear Y axis.
Last edit: 26 Aug 2020 13:09 by Aciera.
- jean-claude
26 Aug 2020 15:12 #179574
by jean-claude
The C just a rotary axis and B the only spindle.
27 Aug 2020 02:07 - 27 Aug 2020 02:13 #179665
Ok then your machine is milling machine with a horizontal spindle and a rotary A axis without a Y axis:
your X is the Z,
your Z is the X,
your C is the A,
and the Y does not exist.
In many CAM software you can define the rotary A as substitute for the missing Y so the tool path for Y is wound around the A axis. I have no experience with Fusion360 so I can't comment on how to do it there but I would expect it be able to do that.
The post processor would be the same as for a regular 4 axis linuxcnc mill.
so you might want to change the title of the post to get more information regarding 4 axis milling in fusion360
your X is the Z,
your Z is the X,
your C is the A,
Last edit: 27 Aug 2020 02:13 by Aciera.
- jean-claude
27 Aug 2020 02:30 #179667
by jean-claude
Thank you very much for this research track.
- jean-claude
27 Aug 2020 08:42 #179687
by jean-claude
I looked in Fusion360 and the rotation part is paying. Too bad because it's for leisure.
- anfänger
- Thank you received: 271
27 Aug 2020 14:07 #179724
by anfänger
Replied by anfänger on topic Add a rotary axis B on a lathe
are you sure? I can generate 4 Axis tool paths but I never tried to post process cause ma mill only as three axis at the moment
Time to create page: 0.150 seconds
