Radios to end of arc differs
- paulsao
- Thank you received: 22
07 Oct 2021 17:18 #222497
by paulsao
Replied by paulsao on topic Radios to end of arc differs
I have the same problem ...
- paulsao
07 Oct 2021 17:42 #222500
by paulsao
- paulsao
10 Oct 2021 20:37 - 10 Oct 2021 20:37 #222811
by paulsao
Well, if someone had the same error, please check the final part where the nozzle inlet and outlet is configured, I had it configured in an arc shape and it is where the problems that I had with different arcs were presented, now I use straight inlets at 90 degrees for exterior profiles and I no longer have those problems, everything works fine !!!
Last edit: 10 Oct 2021 20:37 by paulsao.
- Thank you received: 4155
11 Oct 2021 06:02 #222839
Replied by rodw on topic Radios to end of arc differs
There is a gcode setting to select absolute or relative coordinates for arcs. I wonder if Fusion has it wrong?
- phillc54
- Thank you received: 2100
11 Oct 2021 06:33 #222845
by phillc54
Replied by phillc54 on topic Radios to end of arc differs
If you look at the posted gcode that doesn't seem to be the issue.
- paulsao
14 Oct 2021 12:49 #223103
by paulsao
Actually now I want to cut a letter for a sign and I have that same radius problem, I change tolerance, torch diameter in Fusion and I don't know what else to do to fix that problem.
- Thank you received: 7509
14 Oct 2021 16:02 #223119
Replied by tommylight on topic Radios to end of arc differs
Have you tried using Inkscape ?
- paulsao
14 Oct 2021 16:17 #223123
by paulsao
I generated the same file in sheetcam and it works very well, but with fusion 360 I have that error, now I'm going to with inkscape but ideally everything works in Fusion
- paulsao
14 Oct 2021 16:28 #223124
by paulsao
Inkscape already has the post processor for Plasmac or do I have to download it from somewhere?
14 Oct 2021 16:45 #223126
The following user(s) said Thank You: paulsao
Time to create page: 0.111 seconds
