Radios to end of arc differs
14 Oct 2021 16:55 #223128 by phillc54
Replied by phillc54 on topic Radios to end of arc differs
Are you using the Post Processor from here:
forum.linuxcnc.org/plasmac/38438-plasmac-post-processors#159042
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
14 Oct 2021 16:56 #223129 by paulsao
Replied by paulsao on topic Radios to end of arc differs
Thank you very much Tommy for your time and your help I am already in the final steps to have the machine 100%
  • paulsao
  • Elite Member
  • Elite Member
14 Oct 2021 17:01 - 14 Oct 2021 17:03 #223130 by paulsao
If Phill I am using that same pp for Fusion, it works very well I have cut very good pieces of great quality and precision, but when I have arcs I have that problem and I have to use sheetcam.
Last edit: 14 Oct 2021 17:03 by paulsao.
14 Oct 2021 17:54 #223133 by phillc54
Your code shows the same error here, I tried changinging CENTER_ARC_RADIUS_TOLERANCE_MM in the .ini file but that didn't help.
It seems that there is something not quite right with the Fusion post processor, sorry but I can't help with that.
  • paulsao
  • Elite Member
  • Elite Member
15 Oct 2021 14:53 - 15 Oct 2021 14:53 #223222 by paulsao
Well after trying many times I realized that the arc errors that I had were due to the Smoothing function of Fusion 360 so I tried with many values, I read in an autodesk forum that it must be 1 to 4 times than the tolerance cut but I did not find the value to make it work so I am working without using that function.
Last edit: 15 Oct 2021 14:53 by paulsao.
The following user(s) said Thank You: phillc54, tommylight
  • Moderator
  • Moderator
19 Oct 2021 17:48 #223600 by tommylight
Replied by tommylight on topic Radios to end of arc differs
Merged two topic with the same subject started by the same user.
Please refrain from starting new topic for the same subject, and use the search feature.
The following user(s) said Thank You: phillc54, paulsao
