- GCode and Part Programs
- CAD CAM
- Post Processors
- Fusion 360
- LinuxCNC post-processor error. Please assist
- Shisui2013
09 Aug 2022 08:30 - 16 Aug 2022 18:12 #249381
by Shisui2013
LinuxCNC post-processor error. Please assist was created by Shisui2013
I purchased a DIY CNC plasma table. I've got everything assembled and running; I've even managed to get the machine to run the g code that the previous owner had programmed into it. I wanted to sketch and use fusion's CAM capabilities because I am familiar with it. However, I receive a message stating that plasma is not supported when I attempt to publish process using LinuxCNC as the post. Why am I misusing this? LinuxCNC reportedly supports plasma.
youtube thumbnail download
Last edit: 16 Aug 2022 18:12 by Shisui2013.
- JPL
- Thank you received: 118
09 Aug 2022 09:37 - 09 Aug 2022 09:38 #249385
by JPL
Replied by JPL on topic LinuxCNC post-processor error. Please assist
Yes, linuxcnc support plasma as well as fusion 360. AFAIK, the problem is that there's no 'official' post available for this. See here: cam.autodesk.com/hsmposts? You will find many posts for 'waterjet/laser/plasma' but none of them are for linuxcnc.
Then, a quick search at Autodesk HSM community revealed this posts: forums.autodesk.com/t5/hsm-post-processo...ocessor/td-p/8112836 See the linuxcnc plasma post near the end of the thread. Maybe this would work for you. If not I would suggest to ask there.
Last edit: 09 Aug 2022 09:38 by JPL.
- snowgoer540
- Thank you received: 903
09 Aug 2022 16:09 #249405
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC post-processor error. Please assist
Your post is a bit vague. Are you running plasmac or qtplasmac? Or is some other software driving the table?
If you are running plasmac or qtplasmac, you could try this post:
forum.linuxcnc.org/plasmac/38438-plasmac-post-processors#159042
- CAD CAM
- Post Processors
- Fusion 360
Time to create page: 0.073 seconds
