Hallo fairngs,
oh my good, how much information, and the biggest error is in your first post!
You are using a XYZAU configuration, but you use JOINT 0,1,2,3 and 4. The U is joint 6!!!
X = 0
Y = 1
Z = 2
A = 3
B = 4
C = 5
U = 6
V = 7
W = 8
Also you do load a lot of userpanels, please do not implement them, until your basic config does run, as they may cause errors, whitch can only be seen on terminal.
Now lets talk about your mixing of 2.7 and 2.8 and menu starts etc.
if you clone linuxcnc, you get several branches, one of them is gmoccapy_5_axis, another one is master
If you check out gmoccapy_5_axis and compile it, and rip environment and start it from the same terminal your rip_environment, you will get linuxcnc 2.7, because gmoccapy_5_axis is based on that.
If you check out master, and do a make than!!! You have to do a make after each branch change! You will get linuxcnc 2.8.
So I see, you are missing some basics.
so please do the following in a terminal:
cd linuxcnc-dev
git checkout gmoccapy_5_axis
cd src
make clean
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
If all do compile without errors, you will get the linuxcnc config picker screen. Please select from sim folder gmoccapyXYZAB and run that config.
If that does show up, you may begin to switch to your config, but do that step by step!
Start all test from the open terminal, as if you close it, you will need to do again the rip-environment!, and watch for outputs in the terminal.
The messages from gmoccapyy you posted a thread ago, is not complete and the part you posted does not show relevant errors.
Norbert
