Need testers for gmoccapy_5_axis
10 years 4 months ago #76022 by eighthaxis
OK I pulled from the branch gmoccapy_2.
I have attached the terminal session via mousepad for you to review.
I copied the gmoccapy directory from linuxcnc-dev../sim to linuxcnc/configs directory and named it sim.gmoccapy_2
I tried gmoccapy_XYZAB.ini to no avail. I get errors saying gmoccappy can't handle more than 4 axis.
I attached a second doc with all of the errors.
Please let me know where to go from here.
Aloha,
Josh
File Name: gmoccappy_...tall.txt
File Size:20.78 KB
File Name: gmoccapy_X...rors.txt
File Size:61.52 KB
File Size:20.78 KB
gmocappy_2
Thank you again for all of your help.
The topic has been locked.
10 years 4 months ago #76027 by newbynobi
If you get errors, why do you ignore them?
Solve them, otherwise you will never get a working system!!!!!!
f you get errory, please solve them before doing the next step!!!!!!!!!! distributable due to a license incompatiblilty with LinuxCNC (some portions GPL-2 only) and Readline version 6 and greater (GPL-3 or later). configure: error: To configure LinuxCNC in this way, you must invoke configure with "--enable-non-distributable=yes". Note that on Debian-based systems, you may be able to use libreadline-gplv2-dev instead. make: Failed to remake makefile `Makefile.inc'. make: Failed to remake makefile `Makefile'. josh@Mill:~/linuxcnc-dev/src$ sudo make setuid
Norbert
10 years 4 months ago #76034 by eighthaxis
newbynobi wrote: If you get errors, why do you ignore them?
Norbert
Just ignorant.
Thank you very much for your help.
I have successfully installed gmoccapy with all five axis!
Being that you said pnconfig is not compatible with gmoccapy what is the best way to configure the I/O for the 7i77?
Aloha
10 years 4 months ago #76042 by newbynobi
@eightaxis
I am glad, you make it work.
You may use pncconf to get 4 axis and the IO ' configured and edit this file with gedit or notepad to get gmoccapy and the 5'th axis.
I do it that way, I just build a 3 axis machine and edit the INI and HAL files.
First I get rid of all unneded stuff, i.e. in the INI File all the unneded hal entries as shutdown.hal etc.
Second I make the file more easy to edit, I just cut and paste parts arround and split the huge hal file in separate smaler files. I have than a machine.hal file and a spindle.hal and a doors.hal and a toolchange.hal, a coolant.hal, etc. The only problem is, that you need to add all the files in the right order in your INI File, as you may need a component in various files and they are only allowed to be loaded ones.
So good luck.
Norbert
10 years 4 months ago #76122 by eighthaxis
Would you please post an example gmoccapy ini file that is working in five axis?
I am having trouble figuring out what to keep or not keep or overwrite. Some of it is straight forward others not so much.
Which HAL files for example. I am posting the two ini's I am trying to integrate per your suggestion for your evaluation.
File Name: gmoccapy_X...inal.ini
File Size:8.17 KB
File Name: my_LinuxCN...onfg.ini
File Size:3.5 KB
Aloha
10 years 4 months ago #76124 by eighthaxis
Looks like I need to do the same
with the main HAL files as well. Here they are.
Any suggestions would be appreciated.
File Name: my_LinuxCN...onfg.hal
File Size:14.02 KB
File Name: core_sim_XYZAB.hal
File Size:2.3 KB
Moderators: newbynobi, HansU
Time to create page: 0.107 seconds
