Need testers for gmoccapy_5_axis
10 years 11 months ago #65626 by auto-mation-assist
I found G21 in the .ini file and changed it to G20. Axis X,Y,Z and A now display in inches. But the dro part of the front panel shows axis A angles in +/- values while the white angle indicators in the preview screen show the correctly in degrees. My B axis is linear and its dro displayed in inches even when the G21 code was in the .ini file. Should it not have displayed in mm with the G21 code?
I test each axis individually on the bench with just one motor and encoder feedback going a Leadshine DCS810 and also feeding the encoder a.b and index signal to the appropriate quad decoder for routing to each axis pid function. The quad decoder inputs on X,Y,Z and B inputs will later be fed by the glass scales that are on those axis already and parameters adjusted as required. The machine this system is going on is not quite ready since it does not have all the required limit and home switches installed..
The topic has been locked.
10 years 11 months ago #65669 by newbynobi
A,B and C can not be linear!!!!
This are the rotation axis around the linear axis.
If you need aditional linear axis you have to use U, V or W.
So this seems not to be gmoccapy specific.
Norbert
The following user(s) said Thank You: auto-mation-assist
10 years 11 months ago #65769 by auto-mation-assist
Norbert I have lost my file to configure your 5 axis version of Gmocappy during my computer swamp. I have searched for hours trying to find a link to download the file with no success. If possible can you provide me with a link to where I can download a copy?
10 years 11 months ago - 10 years 11 months ago #65792 by newbynobi
sudo apt-get install git-core gitk git-gui git config --global user.name "Your full name" git config --global user.email "you@example.com" git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev sudo apt-get install libboost-python1.49-dev libmodbus-dev libusb-1.0-0-dev libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libreadline-dev tcl8.5-dev tk8.5-dev cd linuxcnc-dev git checkout gmoccapy_5_axis cd src ./autogen.sh ./configure make sudo make setuid cd .. . ./scripts/rip-environment linuxcnc
Can you follow?
If you have git installed, you may not need all steps.
All out of memory, I am not sure with the git checkout command, you can do that one also using git gui
Norbert
Last edit: 10 years 11 months ago by newbynobi.
10 years 11 months ago #65840 by auto-mation-assist
Norbert the links you posted help me a lot. I'm impressed by gmocappy and its flexibility. On my initial install that I did several weeks back I did have a real long line of numbers running through part of the lower left side of the screen. When my new install is completed I will let you know if that line appears again.
10 years 11 months ago #65867 by newbynobi
The longer numbers are caused by a wrong ini entry, if yiu used a older version of stepconf.
Please see the official docu, under known problems.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.356 seconds
