tool change
10 years 11 months ago #65201 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic tool change
Looks like you have almost everything correct.
You have a # in front of the line
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
Remove the # to uncomment the line
Also you still have the value of MAXPROBE being a positive value. If positive is up on your Z axis then you want the value of MAXPROBE to be a negative value so that it moves down when probing.
There are also some leading spaces on some of the lines in your INI file. I don't think this will cause and issue but you might remove them to make it more consistent.
The following user(s) said Thank You: newbynobi, thor44
10 years 11 months ago #65202 by LearningLinuxCNC
Another thing that I noticed is that you have
FEATURES =30
followed by
FEATURES = 12
You can remove the FEATURES = 12 since the previous statement already covers that.
10 years 11 months ago #65203 by thor44
Replied by thor44 on topic tool change
now the machine moves to the tool change position and the message appears on the screen to change the tool and click "ok" so far so good but when I click ok a new error message appears that a probe move will exceed the z axis negative limit.
Where is the probe file? What probe file is it using?
10 years 11 months ago #65204 by LearningLinuxCNC
The way the tool measurement routine works is that it moves to the "CHANGE POSITION" you do the tool change. Then it moves to the "TOOLSENSOR" X and Y position then the "TOOLSENSOR" Z position. After that it begins a probing move in the Z axis with a maximum probing distance of "MAXPROBE"
It sounds like you need to tweak your "MAXPROBE" value to make the probe routine work.
All of these specific moves can be found in the change.ngc file in the macros folder.
10 years 11 months ago #65205 by LearningLinuxCNC
Looking at the AXIS_2 section in your INI file. I see that your 0 position is in the middle of the axis. The min limit is -3.9 and the max limit is 3.
Your TOOLCHANGE position is at -3 so I assume the the -3 position is near the top of the Z axis travel. I told you earlier to make the MAXPROBE value negative but it appears that you have positive Z travel in the downward direction. This is rather unconventional and may cause issues down the road.
Moderators: newbynobi, HansU
Time to create page: 2.030 seconds
