tool change
10 years 11 months ago #65101 by thor44
Replied by thor44 on topic tool change
here is the config folder that I am using, it has all the files that I have.
File Name: my-mill.zip
File Size:233 KB
10 years 11 months ago #65102 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic tool change
Comment out the follwing lines in your HAL file.
# loadusr -W hal_manualtoolchange # net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change # net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed # net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number # net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
Delete the contents of the gmoccapy_postgui.hal file and replace it with the following
net tool-change gmoccapy.toolchange-change <= iocontrol.0.tool-change net tool-changed gmoccapy.toolchange-changed <= iocontrol.0.tool-changed net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
This should result in a single toolchange dialog box that will take the offsets from the tool table for the new tool. This will not measure the length of the new tool. You will have to go throught the configuration steps in the Auto Tool Measurement section of the gmoccapy documentation to get the tool length measurement to work.
The following user(s) said Thank You: thor44
10 years 11 months ago #65154 by thor44
Nitro,
Thanks for the help so far it works perfectly.
Orson
10 years 11 months ago #65180 by thor44
Has any one used the auto tool measurement in Gmaccopy?
I think I have all the settings correct but it doesn't work.
Does Amy one have any ideas?
10 years 11 months ago - 10 years 11 months ago #65182 by LearningLinuxCNC
Have you changed things in your config since you last posted it?
If so post it again and I will take another look.
What exactly is it doing when you try to use the auto tool measurement? What is not working?
Last edit: 10 years 11 months ago by LearningLinuxCNC. Reason: Added another question.
10 years 11 months ago #65195 by thor44
my understanding is that when a tool change is given in the g code file the machine moves to a specified location the tool is changed manually and then the machine automatically does a tool touch off for the tool height and then returns to the g code file to finish the job.
When the tool change comes up the message appears and when you click continue the machine continues, no movement to the specified location and no touch off.
Here is the newest config files.
File Name: my-mill-2.zip
File Size:237 KB
Moderators: newbynobi, HansU
Time to create page: 3.662 seconds
