Feature request: rapid and feed override.
10 years 9 months ago #68531 by newbynobi
Appearance typo and jog-error message is fixed in 2.6 / 2.7 and master.
Norbert
10 years 9 months ago #68538 by DaBit
Nice! I will pull a fresh copy of master somewhere this week.
Jogging in MDI would be nice, but something like 'if (jog-* == active && current_mode != MODE_AUTO && current_mode != MODE_MANUAL) change_mode (MODE_MANUAL); ' would do too, so the time being.
A nice solution would be far more complex, and usually evolution wins it from revolution.
10 years 9 months ago #68584 by newbynobi
@DaBit,
unfortunately that is not so simple. I could make that change with a few lines of code, but I do not know how that will take influence if you use a MDI command from your own button, or if you use MDI_COMMANDS from the INI file. And there are some more ways to execute a MDI command. So there might be a lot of situations to take care of.
But I will not forget about that.
Norbert
10 years 9 months ago #68607 by DaBit
The problem is the unability to jog when the machine is idle, unless you are in a specific 'manual' mode. That is a different thing than executing MDI commands (strangely enough you can execute an MDI command through halui or something when the machine is in manual mode, so the mode dependancy is not even consistent).
Basically I would want to be able to jog the machine whenever the trajectory planner is idle. This is slippery territory, but being able to jog when a running program is paused (and therefore the TP is idle) is a useful thing too imho, for example. Things are about to go wrong, pause, jog up, inspect something, clear some chips or whatever, jog down, continue. It might also cause problems because the subsequent program move is not the intended one, but if you screw things up that's your responsibility.
I personally hate it when software tries to make things idiotproof by just not allowing actions. It doesn't even work, because when you make things idiotproof someone just proves himself to be a better idiot and everybody else is left with 'I want to, but they won't allow me..'.
I still want that 'shut up and just do what I ask you to do' button in Windows too, for example :laugh:
10 years 9 months ago #68702 by newbynobi
@DaBit,
i mostly agree, but jogging while paused is dangerous! If you want that feature, you can include it with the moveoff hal comp. It does work fine.
Let me see what I can do with jog on MDI, I have a idea to make a work around, I will contact you if I am ready for tests.
Meanwhile I have added the option to disable DRO Mode change with a click oin the DRO, just see the doku in 2.7 branch or just on the settings page. It is included in release 1.5.6
Norbert
10 years 9 months ago #68747 by DaBit
I do not expect anyone to fully agree with the previous post. There is a lot of personal opinion in there.
Life is a bit busy at the moment, but I will pull a fresh copy from master on the mill somewhere this week; that will give me the new gmoccapy. The lathe stays at 2.7.3 until everything else has stabilised (build is not finished yet).
Moderators: newbynobi, HansU
Time to create page: 0.341 seconds
