Feature request: rapid and feed override.
10 years 8 months ago #70588 by alessandro torre
In my opinion will be great, if there is the possibility to set and switch the velocity between mm/s and mm/min.
It depends by the application. In our case, we adopt this GUI for 3d printing, and so in this field is mostly used mm/s.
At last, due to the fact that I'm not a great designer. There is a way to add the temperature setting and measuring of the extruder and heated Bed with the same design of the feed override/Max velocity?
In attached my actual first attempt but it's not like the rest of the GUI.
Thank you in advance
10 years 8 months ago #70601 by newbynobi
Halo Alesandro,
it has allready be done ;-)
I do hope you know Spanish, as this page is in that language.
There are several parts explaining the possible changes of gmoccapy.
Norbert
5 years 1 month ago - 5 years 1 month ago #221007 by slammers
I actualley prefer the override to be similar to the way Path Pilot does it. I would like an override that limits max velocity (both rapid and feed) and another for feed alone.
Is it possible to customize gmoccapy to implement the old way? I have experimented with connecting an encoder to both gmoccapy's feed and rapid overrides but because the rapid and feed to not have the same range, (0 to 100 vs 0 to 120) they get out of sync quite fast.
Last edit: 5 years 1 month ago by slammers.
5 years 2 weeks ago #223206 by jasen
post picture dude
5 years 3 days ago #224673 by newbynobi
the request you have I not customible. If you want teh old way, you will need to edit gmoccapy files.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.063 seconds
