- Thank you received: 2181
tecno wrote: Is this fool-proof in the trajectory planner to issue FRO in running G-code?
I hate this behavior from linuxcnc too!, but it is not gmoccapy related. I am a little surprised that you get an error. Do you use the gmoccapy hal pin?- When I try to jog when MDI mode is selected but the machine is idle, I get the EMC_BLABLA error 'cannot do that'. Quite irritating; when positioning I use both MDI to go to known coordinates (e.g. G0 X0Y0 to position the mill in the XY plane) and jogging (to find the Z height for touchoff when I cannot use the probe, for example).
Will correct that- In settings 'Apearance' is written wrong.
Took that to my to do list, to check if I can realize that with a settings switch.- Clicking on the DRO to change to absolute/DTG mode is irritating; I never do that on purpose, only by accident. Gmoccapy already shows the absolute and DTG numbers. I would like to have a setting to only have one of the relative/absolute/DTG modes displayed, plus homed/not homed.
I do agree 100 % with you, the tool table and tool editing is a mess! I would like to integrate a new "tool editing with moving through the cells with TAB, and add also wear offsets and some more stuff, like small images. Unfortunately, that is some coding work and due to gtk2 it is not as easy as I imagined, Just let me some new stuff for gmoccapy 3.0- Editing the tool table needs some getting used to. You need to check the box in front of the tool you want to edit, click on the field, enter a value, and then you HAVE to press enter otherwise it is not remembered. And then there is the 'apply' button; if you forget to press that one and go to another screen (to see the DRO for example) and back the changes are lost.
Yes, it would be time and linuxcnc-features is on the best way to make it. But we are very far away from a point and Click configuration system. I do not think, that that will ever happen, as linuxcnc offers to much possibilities to include all of them.Maybe it is time to integrate a few of these externals. You more or less did that with tool measurement too. Probe-screen is a good candidate, as well as features or ngcgui. That allows people to actually do something with the software after installing. If someone doesn't need it then that tab simply isn't used.
newbynobi wrote: I hate this behavior from linuxcnc too!, but it is not gmoccapy related. I am a little surprised that you get an error. Do you use the gmoccapy hal pin?
and make it "Ausssehen" :whistle:
So feel free to make a schedule or a little sketch, "How should a beginner linuxcnc config be? We may then make such a sample config as start point and add later a GUI to set more parameters. Begin with the hardware, then the GUI, that the options etc.
Yes:
# MPG buttons to gmoccapy jog
net jog-x-plus xhc-hb04.button-macro3 => gmoccapy.jog-x-plus
net jog-x-minus xhc-hb04.button-macro1 => gmoccapy.jog-x-minus
