screen resolution
3 years 9 months ago #262039 by probamo
Replied by probamo on topic screen resolution
2.7.15
3 years 9 months ago #262040 by probamo
"gmoccapy_lcd7" this does not work with 2.8 edition unfortunately.
3 years 9 months ago #262041 by HansU
Replied by HansU on topic screen resolution
If you are using 2.7 then the instructions from machinekit-gmoccapy-lcd7.blogspot.com/20...con-respecto-la.html should work.
But then I wonder why you are asking about 2.8 or 2.9?
Is there anyone that could provide apps for 2.8 or 2.9 edition. This works only at 2.7?
It would be nice if you can give us more information to be able to help you.
3 years 9 months ago - 3 years 9 months ago #262042 by HansU
I guess you consider upgrading to LinuxCNC 2.8 or 2.9 but the not supported screen resolution would be a blocker for that? Is that right?
Last edit: 3 years 9 months ago by HansU.
3 years 9 months ago #262043 by probamo
In fact I found Siemens industrial comps (x386) to manage CNC. Two of them have parallel ports in there therefore 2.7.15 work well there, and two machines works as a charm. The third one is new generation of the same industrial comp w/o parallel port. I have parallel port pci card and there is free slot for it. I put it there, unfortunately only kernel 4.0+ can recognize adds. 2.7.15 works with kernel 3.0+. That is why I am chasing small resolution for 2.8 which run at 4.0+ kernel.
3 years 9 months ago #262045 by HansU
For 2.8 I will not do such a modification. But for 2.9 I am planning to provide a sample config for that. Let me know if that would help you as well.
Moderators: newbynobi, HansU
