Truning screen 90 degree
9 years 7 months ago #88901 by newbynobi
Replied by newbynobi on topic Truning screen 90 degree
You can not mix both releases! The glade file only has some changes in names and widgets, but the main python file and libs has very relevant changes.
The shown release number is hard coded in gmoccapy.py file,not in the glade file.
Norbert
9 years 7 months ago #88915 by mpvriens
Replied by mpvriens on topic Truning screen 90 degree
Understand, so i use the same releases, as they come with the same package when updating linuxcnc 2.8 master,
still when i try to edit the gmoccapy.glade file, he will not accept the changes,I just use the gmoccapy.glade file from the gmoccapy folder, load it to the glade-gtk2 program, and save it again to the same folder,
Marius
9 years 7 months ago #88970 by newbynobi
Ok, i am sure you do not start glade from rip environment.
If you start it from menu, some libs will not be availiable.
You do not get an error, but the glade file will be destroyed.
Please use diff to check the differences.
Norbert
9 years 7 months ago #88987 by mpvriens
Have created a rip environment, and have started glade-gtk2 from linuxcnc.dev , loaded the gmoccapy.glade file from usr/share/gmoccapy, saved it to documents ( as i don't have write permision on gmoccapy, turned on sudo thunar, to copy the file into the gmoccapy file , same error
9 years 7 months ago #89034 by newbynobi
Without you config, it is difficult to help.
please post both glade files and use diff or meld (grafical diff) to check for the differences.
Norbert
9 years 7 months ago #89048 by mpvriens
We found changing the screen on a text editor will do the trick
Marius
Moderators: newbynobi, HansU
Time to create page: 0.127 seconds
