What is this, graphics not aligned!
- tecno
- Thank you received: 127
07 Jul 2018 11:49 #113661
by tecno
What is this, graphics not aligned! was created by tecno
- tecno
07 Jul 2018 15:32 #113677
by tecno
Replied by tecno on topic What is this, graphics not aligned!
- Thank you received: 2181
07 Jul 2018 18:48 #113704
Replied by cmorley on topic What is this, graphics not aligned!
Did you adjust the X axis origin during the run?
If you did how did you adjust it ? With MDI command?
I have seen this caused by the graphics not being updated after an origin change.
Chris M
Chris M
- Thank you received: 1482
07 Jul 2018 21:48 #113729
Replied by Todd Zuercher on topic What is this, graphics not aligned!
Not sure what is causing your problem. But on a machine with UVW axis changing the U potion can do that.
- tecno
08 Jul 2018 00:27 #113740
by tecno
I just home the lathe and load the file and run it.
Cheers from hospital emergency, hopefully back later today
08 Jul 2018 00:28 #113741
Replied by andypugh on topic What is this, graphics not aligned!
It looks like you somehow have a tool diameter being compensated despite (probably) having no tool loaded.
- tecno
08 Jul 2018 00:32 #113742
by tecno
Tooltable is empty that is no numbers anywhere.
Have tried M6T1 that is in table no difference. The pawn file has no tool!
08 Jul 2018 01:11 #113749
I am as puzzled as you then.
It's not something I have seen.
If you wipe the screen and run again, do you get the same thing?
- tecno
08 Jul 2018 02:10 #113754
by tecno
Still same problem.
Now back home from hospital emergency and hopefully I get some sleep.
- tecno
08 Jul 2018 13:00 #113803
by tecno
So, I started to look at gmoccapy_preferences as this is the place where things should be done.
At the bottom of the file I found these lines
radius offset_axis_x = 0
offset_axis_x = 45.0
radius offset_axis_z = 0
offset_axis_z = 0.0
And down to the shop and edit the preferences = but NO GO
So I am a bit puzzled mildly speaking why this phenomena exists, also same issue in MILL so it is some thing odd going on here.
Hopefully Norbert will chime in and enlighten us
offset_axis_z = 0.0
Moderators: newbynobi, HansU
Time to create page: 0.326 seconds
