What is this, graphics not aligned!
- newbynobi
- Thank you received: 394
08 Jul 2018 19:01 #113829
by newbynobi
Replied by newbynobi on topic What is this, graphics not aligned!
Two possible reasons:
- Check xour INI and compare very carefully, all Joint an AXIS values, such eeviations can be caused, because the numbers of both necessary entries in Joints and axis ARE NOT THE SAME.
- just rounding errors in gremlin. But I do not Think that in your speciasl case, as the diviations are realy big in your shown grafics.
The preference file has nothing to do with that.
Norbert
Norbert
- tecno
- Thank you received: 127
08 Jul 2018 19:04 #113830
by tecno
Replied by tecno on topic What is this, graphics not aligned!
Running 2.7.14 not master.
- Hakan
- Thank you received: 463
09 Jul 2018 12:03 #113866
by Hakan
Replied by Hakan on topic What is this, graphics not aligned!
I too have this non-aligned graphics, both in 2.7 and now in master.
09 Jul 2018 12:30 #113868
Replied by andypugh on topic What is this, graphics not aligned!
One quick check (and it probably isn't this)
(DEBUG, #5410)
(DEBUG, #5410)
- Thank you received: 7501
09 Jul 2018 13:23 #113871
Replied by tommylight on topic What is this, graphics not aligned!
Zoom out of the preview and check if you have a green sphere somewhere.
That sure looks like some offsets are still active.
- tecno
09 Jul 2018 13:31 #113872
by tecno
G40 and G49 are active when I start gmoccapy so there should not be any offsets.
Moderators: newbynobi, HansU
Time to create page: 0.162 seconds
