gmoccapy plasma struggle bus
- jimmyrig
- Thank you received: 42
18 Sep 2018 21:08 #117731
by jimmyrig
gmoccapy plasma struggle bus was created by jimmyrig
i've setup a few machines before in axis but gmoccapy plasma is kicking my butt. I've looked over the getting started documentation here wiki.linuxcnc.org/cgi-bin/wiki.pl?Gmoccapy_Plasma and here linuxcnc.org/docs/devel/html/gui/gmoccapy.html
but cannot seem to find how to convert a axis hal and ini file to gmoccapy plasma
i copied the gmoccapy sim file, made an hal+ini file with step config (2 parallel ports), then proceded to delete the "sim" files out of the gmoccapy ini file and linked my axis hal file instead (along with the signal and plasma hal files). i then coppied the MOTOR values over so everything was lined up
the error i get is cant find "gmoccapy2.glade"...
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/jimmy/linuxcnc/configs/5x10Plasma'
Machine configuration file is '5x10Plasma.ini'
INIFILE=/home/jimmy/linuxcnc/configs/5x10Plasma/5x10Plasma.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Found file(REL): ./table.hal
Found file(REL): ./plasma.hal
Found file(REL): ./signals.hal
Starting DISPLAY program: gmoccapy
task: main loop took 0.104681 seconds
task: main loop took 0.015092 seconds
**** GMOCCAPY GETINIINFO ****
Preference file path: gmoccapy_preferences
**** GMOCCAPY INFO ****
**** No gmoccapy2.glade file present ****
**** audio available! ****
**** No virtual keyboard installed, we checked for <onboard> and <matchbox-keyboard>.
**** no valid probe config in INI File ****
**** disabled tool measurement ****
**** GMOCCAPY INFO: Gcode.lang found ****
**** GMOCCAPY INFO : inifile = /home/jimmy/linuxcnc/configs/5x10Plasma/5x10Plasma.ini ****:
**** GMOCCAPY INFO : postgui halfile = gmoccapy_postgui.hal ****:
Xlib.protocol.request.QueryExtension
Killing task linuxcncsvr, PID=25976
Killing task milltask, PID=26043
task: 3157 cycles, min=0.000020, max=0.104681, avg=0.001163, 2 latency excursions (> 10x expected cycle time of 0.001000s)
the error i get is cant find "gmoccapy2.glade"...which appears to be the coolant file, so i went to a normal gmoccapy setup and copied the file over to the plasma and this was what i got...not sure what the issue is here..
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
task: main loop took 0.027556 seconds
task: main loop took 0.013195 seconds
**** gmoccapy screen 2 found ****
Killing task linuxcncsvr, PID=26660
Killing task milltask, PID=26707
task: 3248 cycles, min=0.000019, max=0.027556, avg=0.001147, 2 latency excursions (> 10x expected cycle time of 0.001000s)
finally if i copy the plasma.glade and rename it gmoccapy2.glade i actually boot gmoccapy and everything appears normal but a popup window with this message
Found an error!
The following information may be useful in troubleshooting:
File "/usr/bin/gmoccapy", line 4238, in <module>
app = gmoccapy()
File "/usr/bin/gmoccapy", line 249, in __init__
self._init_hide_cursor()
File "/usr/bin/gmoccapy", line 1143, in _init_hide_cursor
self.widgets.window1.window.set_cursor( None )
AttributeError: 'NoneType' object has no attribute 'set_cursor'
clicking ok gives me this errror...not sure what the issue is
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
task: main loop took 0.045948 seconds
task: main loop took 0.010584 seconds
task: main loop took 0.017576 seconds
task: main loop took 0.010684 seconds
task: main loop took 0.017156 seconds
task: main loop took 0.010299 seconds
task: main loop took 0.013882 seconds
task: main loop took 0.024240 seconds
task: main loop took 0.014214 seconds
Killing task linuxcncsvr, PID=27087
Killing task milltask, PID=27145
task: 48885 cycles, min=0.000019, max=0.045948, avg=0.001193, 9 latency excursions (> 10x expected cycle time of 0.001000s)
i am using linuxcnc 2.7.14 (latest version as i understand it).....it seems to be a bug that the coolant window isnt disabled to it crashes when loading....but it wouldnt surprise me if im missing something
hal files and ini are included
thanks for the help
Jimmy
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Found an error!
app = gmoccapy()
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
thanks for the help
Jimmy
- Grotius
- Thank you received: 2349
19 Sep 2018 21:48 - 19 Sep 2018 21:56 #117767
by Grotius
Replied by Grotius on topic gmoccapy plasma struggle bus
Hi Jimmyrig,
Welcome to the linuxcnc forum. I see you are member sinds yesterday. That is good news !!
1. What kind of torch height controller are you using?
2. What kind of linux version?
3. Port and pin hard wiring setup?
4. What kind of plasma inverter and tables do you have, maybe you can upload picture? I skipp chineze plasma machine's, sorry about that. ( this because of chineze service failure's all around the globe, they sell, but they don't service anything, and i don't wanna be the guy who solve's their mistakes for nothing. ) So if it is chineze, please photoshop the picture to a Dutch machine like Voortman Plasma, hmm, it looks like Voortman is using a Siemens display.
Last edit: 19 Sep 2018 21:56 by Grotius.
- jimmyrig
28 Sep 2018 07:35 #118094
by jimmyrig
Replied by jimmyrig on topic gmoccapy plasma struggle bus
for anyone in the future, the way i fixed it was manually editing the stepconf files generated with the wizard to use the gmoccapy plasma parts.
if you download 2.8pre it has gmoccapy as an option in the stepconf wizard making it even easier (still have to move a few things for the plasma)
hope that helps someone
Jimmy
Jimmy
- jimmyrig
28 Sep 2018 07:40 #118095
by jimmyrig
1, i am using my own THC based off of an arduino
2. i went to 2.8 pre after starting with the linuxcnc usb install stick
3. 2 parallel ports, drivers are a gekko g540 that reads in all 4 homing switches separate (XXYZ) and a ebay parallel breakout board to run the plasma pins (arc ok, torch touchoff, ohmic touchoff, and
4. i built the table from scratch.
- mariusl
27 Oct 2018 12:05 #119505
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic gmoccapy plasma struggle bus
Hi Jimmy
Sorry I did not see this thread before. Did you come right with your plasma config?
Just some observation from experience with plasma and usb based devices. I have been building plasma machines for a long time now and have tried many USB based THC systems. I have my own design that was never implemented due to the fact that USB and plasma do not like to live in the same town.
The problem is due to the plasma arc being at between -80to -180V level for most cases and occasionally cause voltage conditions on the USB interface that will cause it to shut down. You cannot revive it unless you unplug.
The most reliable of all is good old analog comparators and some very good filtering on the arc voltage. A window comparator will create UP/DOWN signals that can be used in the THCUD component that comes with Linuxcnc.
There are other issues with using the USB interface that has to do with server loop timing .
Gmoccapy Plasma provides features for the simple UP/DOWN THC and also for a more complex system that no one has used seemingly.
Let me know if you need any help with the setup of Gmoccapy. I did the Plasma section with Norbert but it was a long time ago and I might be rusty.
Regards
Marius
www.bluearccnc.com
- bevins
- Thank you received: 338
19 Nov 2018 16:06 #121002
by bevins
Replied by bevins on topic gmoccapy plasma struggle bus
Not quite following this. Does the gmoccapy plasma work and hal connection made if you go through stepconf?
Is anyone using gmoccapy with plasma? If so, can we see configs somewhere?
Thanks,
Bob
Thanks,
Bob
- Thank you received: 7490
19 Nov 2018 16:26 #121005
Replied by tommylight on topic gmoccapy plasma struggle bus
Rodw is using it, and maybe Icelander.
I use Axis strictly.......for now.
- mariusl
19 Nov 2018 16:52 - 19 Nov 2018 16:54 #121007
by mariusl
Regards
Marius
www.bluearccnc.com
None of the Guis will make the plasma connection through Stepconf. You have to do some work yourself but mostly it is because there are many ways of doing THC. Gmoccapy works very well. What is it that you want to do with it?
Use stepconf to configure the CNC part of your machine and then use the THCUD component and the Gmoccapy Plasma HAL interface to get your plasma working.
As I said, you need to understand plasma and the THC equipment that you want to use. The rest is easy.
P.S. Did you read up on some of the explanation on the wiki / documents?
Regards
Marius
www.bluearccnc.com
Last edit: 19 Nov 2018 16:54 by mariusl.
- mariusl
19 Nov 2018 17:07 #121009
by mariusl
Regards
Marius
www.bluearccnc.com
Also read the man pages for THCUD it explains very well.
linuxcnc.org/docs/devel/html/man/man9/thcud.9.html
Regards
Marius
www.bluearccnc.com
- mariusl
19 Nov 2018 17:25 #121012
by mariusl
Regards
Marius
www.bluearccnc.com
I just read you message again an saw that you use an ohmic sensor for THC. Are you sensing through the torch tip or do you have your own sensor?
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.117 seconds
