Bottom buttons chopped off in window mode
23 Dec 2018 23:21 #122808 by Leon82
I like this interface but in window mode my monitor is chopping the bottom half of the bottom button row off. I tried to adjust the monitor settings and resolution and it doesn't help.
In full screen mode it is fine but I have no idea how to exit full screen mode. may have to try a different monitor ( it's currently a19” insigia TV)
  • Moderator
  • Moderator
24 Dec 2018 09:34 #122819 by tommylight
Replied by tommylight on topic Bottom buttons chopped off in window mode
What interface?
TV's have low resolution, so that might be the reason.
24 Dec 2018 13:34 #122824 by newbynobi
Replied by newbynobi on topic Bottom buttons chopped off in window mode
A 19" Monitor should have a resolution of 1280x1024, so that must be fine!
Can you post a screenshot, as that behavior is very strange on larger resolutions than 800x600
What resolution is given for window mode in the settings page?
You can leave fullscreen, going to the settings page and change the mode or just using ALT TAB if another window is open!
Norbert
The following user(s) said Thank You: Leon82
24 Dec 2018 16:19 #122829 by Leon82
Replied by Leon82 on topic Bottom buttons chopped off in window mode
Norbert
I set the menu bar to auto hide and was able to drag the window up enough see it whole.
I'll have to check out those settings
24 Dec 2018 18:23 #122831 by Leon82
Is there a way to reverse the keyboard jog direction? I want to reverse x and y
24 Dec 2018 21:45 #122845 by newbynobi
Why ??
X- will jog you x axis in negativ direction and X+ in positive!
I do not undestand the reason, but most easy way would be to changevthe order in gmoccapy.glade?
Norbert
24 Dec 2018 22:10 - 24 Dec 2018 22:12 #122846 by Leon82
Why ??
Norbert
I just want To swap the keyboard. My left arrow makes the table go right. And up arrow makes y come forward
This may be normal, I'm used to an mpg at work.
Last edit: 24 Dec 2018 22:12 by Leon82.
25 Dec 2018 03:44 #122858 by Leon82
Where can I find that .glade file?
I ha e been looking at the pinned info and found this as a possible location
/src/po/gmoccapy
The following user(s) said Thank You: newbynobi
25 Dec 2018 22:00 #122890 by newbynobi
If you press the left button and your table moves right, all is OK, as always the tool direction is relevant, not the table!
If you want to change the glade file you do find that one in usr/share/gmoccapy
do not remove ore rename widgets, moving them arround is in most cases OK
Do not forget to backup
Norbert
25 Dec 2018 23:38 #122893 by Leon82
Norbert
If it's normal I'll leave it. I'm just going to have to get used to it.. thanks
Moderators: newbynobi, HansU
Time to create page: 0.137 seconds
