Bottom buttons chopped off in window mode
- Leon82
- Thank you received: 79
- newbynobi
- Thank you received: 394
Norbert
- newbynobi
I just pushed gmoccapy 2.3.4 to master branch.
Here are the changes I made:
ver 2.3.4
- Leon82 mentioned, that offset page did close after editing a column and leaving
the edited cell. This was caused due to a hidden mode change to MDI because
leaving the cell would apply the change using MDI commands from
offset page_widget.py. Gmoccapy now checks the state of the "EDIT OFFSETS"
toggle button and does not react to MDI Mode switch if that button is active.
at the same time, the mode buttons etc. are disabled!
So just pull the latest release, or wait a until tomorrow if you are using buildbot.
I will push this changes in a few minutes also to LinuxCNC 2.7
Norbert
- Leon82
So it was easier than expected:)
ver 2.3.4
Norbert
Awesome!
I'll have to update
- Leon82
Is there a preferred way to set it up?
- newbynobi
first please uninstall buildslave!
That is not needed!!!
Just look at Buildbot linuxcnc
Please look first in synaptic packet manager, depending on the used OS, you may only activate the buildbot repositories.
Norbert
- Leon82
Hallo,
Norbert
Ok thanks
I used the Debian img with Linux cnc preinstalled.
I say Linux cnc in the synaptic packet manager. I don't remember seeing a GMOCCAPY file but I'll double check
- Leon82
GMOCCAPY now version 2.3.4 and Linux cnc also updated my config files.
So the offset menu stays.
Thanks again
- newbynobi
I am glad you get it working and I am satisfied if you like gmoccapy. That is enough for me to go on with the development.
Norbert
