Tool Probe not reacting
- Mike_Eitel
- Thank you received: 183
02 Jan 2019 16:15 #123338
by Mike_Eitel
Tool Probe not reacting was created by Mike_Eitel
Happy new year
I have newest master with gmoccappy
And versers probe screen in a tab.
If I probe it reacts on my probe as expected.
But in gmoccappy when I try to use m6 with tool length it does not recognize the prob signal. Only stops with error that max length is reached.
What have I done wrong / forgotten to connect?
Thx in advance
Mike
Thx in advance
Mike
- newbynobi
- Thank you received: 394
02 Jan 2019 17:33 #123342
by newbynobi
Replied by newbynobi on topic Tool Probe not reacting
What have you connected to what?
May even be, that the probe screen does disable the touch, if the page is not active.
We will need to see your config to go on.
Norbert
Norbert
- Mike_Eitel
02 Jan 2019 18:20 #123346
by Mike_Eitel
Replied by Mike_Eitel on topic Tool Probe not reacting
In the meantime I see some reactions but I'm struggling eventually with basics:
My z runs from top +0 to -119 down
The values in ini and settings that you describe are always positive.
Do I have to give the values positive, means you calculate them from min position
or do I have to give them absolute negative "positions".
Same question for probe in settings.
And one more in the change.ngc is a comment that the following is commented out because of sim. Do I have to delete the comma in the next two lines?
Thx in advance
Mike
Thx in advance
Mike
- Mike_Eitel
02 Jan 2019 18:49 #123349
by Mike_Eitel
Here my config.
And I have the impression that the Z goes near to the tool-probe ( into minus), but them starts probing in the wrong direction ( values count up towards plus)
How can i invert that.
THX Mike
THX Mike
- newbynobi
02 Jan 2019 20:59 #123355
by newbynobi
Did you read this?
linuxcnc.org/docs/html/gui/gmoccapy.html...apy:tool-measurement
To go down use negative value!
Norbert
Norbert
- Mike_Eitel
02 Jan 2019 21:46 #123360
by Mike_Eitel
Hi Norbert
Yes, and start to understand more and more what I read.
I'm already close what I see in your YouTube.
In the moment I set probe hight to z=0 as I see the block hight measured from the probe tripping point, as I can not set a negative value in setting...
Mike
Mike
- Mike_Eitel
04 Jan 2019 12:19 #123466
by Mike_Eitel
Hi Norbert
Sorry if I coming back, think I did not clearly expressed my question.
Up Z is 0, down is - 130
My tool probe is - 90
My block should be -50
But I can not insert negative value in settings.
Or do I think wrong?
Thx in advance
Mike
Thx in advance
Mike
- newbynobi
04 Jan 2019 13:03 - 04 Jan 2019 13:03 #123468
by newbynobi
Last edit: 04 Jan 2019 13:03 by newbynobi.
- Mike_Eitel
04 Jan 2019 13:57 #123478
by Mike_Eitel
No but
My zero is 130 mm higher than tool table.
If I set a positive value for tool switch z wants to go higher then my max 0.
Mike
Mike
- newbynobi
05 Jan 2019 08:44 #123536
by newbynobi
Hallo Mike,
I checked your posted INI File, You did enter a positive MAXPROBE value, but that need to be negative, so change that to be:
Now enter in gmoccapy settings page
blockheight = 95
probeheight = 35
searchvel = 75
probevel = 10
Test with no tool, and press the tool switch with you fingers, report about the results and adapt the values for probeheight and blockheight to your needs.
Anytime a finger on estop!
Norbert
[TOOLSENSOR]
X = -210
Y = -70
Z = -75
MAXPROBE = -100Now enter in gmoccapy settings page
blockheight = 95
probeheight = 35
searchvel = 75
probevel = 10
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.188 seconds
