Tool Probe not reacting
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Jan 2019 12:02 #123540 by Mike_Eitel
Replied by Mike_Eitel on topic Tool Probe not reacting
S U P E R
It works perfect.
And I understand now how and why it works!
THX Mike
P.S. I love the "simpicity" of your gui!
05 Jan 2019 14:50 #123549 by newbynobi
Replied by newbynobi on topic Tool Probe not reacting
Glad it is working!
I would like you to rewrite the docu for the tool measurement, that might helo others. ;-)
Norbert
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
05 Jan 2019 15:14 #123554 by Mike_Eitel
Good idea.
Some small hints might have helped me. Also after I understand I see that all is written in your doc. ;-()
1. Explaining that negative MAXPROBE is needed when you work with tool zero on top with cutting towards higher negative values.
2. State clearer that you calculate the "heights" always a positive values seen from table
Mike
05 Jan 2019 18:25 #123562 by newbynobi
May be it is even worse to joint the two parts of the tool measurements, as in actual doc it is parted.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.126 seconds
