Feed override in auto mode
- Glemigobles
- Thank you received: 18
24 May 2019 10:58 #134799
by Glemigobles
Replied by Glemigobles on topic Feed override in auto mode
The max velocity slider doesn't do anything, even when set to 0.
- Glemigobles
24 May 2019 11:33 - 24 May 2019 11:41 #134802
by Glemigobles
I added the lines:
setp halui.max-velocity.count-enable true
setp halui.max-velocity.direct-value true
And now the slider works in MDI (not manual) BUT it reads the values provided in the ini in machine units per second as machine units per minute (actual feed). So the max value of 60 is now 60 mm/min.
EDIT: solved, I thought I had to add a scale parameter but then looked into the ini file and it turned out MAX_VELOCITY was set to 1 instead of 50.
Now, I'd prefer this to be percentage value and work like an actual feed override slider, but I guess that will have to wait. At least it works.
Last edit: 24 May 2019 11:41 by Glemigobles.
- pl7i92
- Thank you received: 358
24 May 2019 13:10 #134806
by pl7i92
Replied by pl7i92 on topic Feed override in auto mode
you getting it better and betterfrom every day on as you dive deeper to the system
i guess you did check the new halui names
uses halui.axis
not joint for the settings of feedoverride feed and jog
uses halui.axis
- Thank you received: 2181
24 May 2019 19:58 #134845
Well that's not right - The screen slider should work out-of-the-box
Were you using the screen slider or something else?
Chris M
Replied by cmorley on topic Feed override in auto mode
Chris M
- newbynobi
- Thank you received: 394
25 May 2019 20:57 #134927
by newbynobi
Replied by newbynobi on topic Feed override in auto mode
It might help if you post your config folder.
To use the slider, no special commands in hal are needed.
Norbert
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.144 seconds
