Jog Z crashes rtapi_app in lathe mode
- Hakan
- Thank you received: 454
19 Jul 2019 15:04 #139883
by Hakan
Jog Z crashes rtapi_app in lathe mode was created by Hakan
Reproduce by using the latest 2.9 from git.
Start linuxcnc, select sim/gmoccapy_lathe
Jog some distance in Z leads to crash.
Jog in X works fine.
Switching to axis, jog in Z works fine.
Some more info here forum.linuxcnc.org/18-computer/36879-ras...pi-4?start=30#139815
It happens on the Intel PC (so not Raspberry Pi related).
- Thank you received: 2181
19 Jul 2019 16:27 #139900
Replied by cmorley on topic Jog Z crashes rtapi_app in lathe mode
This happens before you home the machine? I seem to confirm that.
This should also affect the 2.8 branch that is coming out.
And yes this is a joint vs axis number problem.
joints in a lathe config are numbered 0 and 1
Axes are numbered 0 and 2
It's not documented very well (and I'm not sure it's the best implementation)
I just noticed this when working on qtvcp and was trying to get a discussion of a solution on the linuxcnc dev list
Chris M
Chris M
- Hakan
19 Jul 2019 17:52 #139903
by Hakan
Replied by Hakan on topic Jog Z crashes rtapi_app in lathe mode
Yes, before homing. But I just tried and it also happens after homing.
The problem can be seen in the simulator so everyone can reproduce it.
This must be something recent. I have been using a 2.8 gmoccapy for a long time.
- Thank you received: 7481
19 Jul 2019 18:49 #139905
Replied by tommylight on topic Jog Z crashes rtapi_app in lathe mode
Linuxcnc 2.8pre, gmoccapy 2.3.3.4, linux mint, preempt rt, lenovo m93:
No such issue before or after homing.
Will test other versions later and report back, need food.
- Hakan
19 Jul 2019 18:53 #139907
by Hakan
Try latest one, there is where I have seen it.
19 Jul 2019 18:57 #139908
Are you trying the lathe config?
19 Jul 2019 19:11 #139910
If I home the lathe config, I can't see the problem in master.
This makes some sense to me as the probable problem is linuxcnc has been directed to jog joint 2 which there isn't one. In axis mode the value 2 = X axis.
So there are two problems here -linuxcnc shouldn't crash if you ask it to jog a joint that is not available, and Gmoccapy needs to use different values for jogging based on joint or axis mode or linuxcnc needs to be smart enough to jog the right axis based on the joint number.
Chris M
Chris M
19 Jul 2019 19:31 #139914
Will do that later, i have on two laptops and a PC.Try latest one, there is where I have seen it.
19 Jul 2019 19:32 #139915
Yes of course, the metric version.
19 Jul 2019 21:56 - 19 Jul 2019 21:59 #139930
Hmmmm something fishy going on there:
Two laptops with Mint 19.1, preempt rt, Linuxcnc 2.9pre0.228, gmoccapy 2.3.5 sim lathe metric
Both will start, exit e-stop, and as soon as enable is active it will not react to anything any more, not even close, it has to be forced to quit.
Both work perfectly well and do not crash with the normal gmoccapy, the first in the menu.
Note, one of these laptops can run Linuxcnc with a Mesa 7i92 for days perfectly, the other tends to drop the communication at random from 3 to 30 minutes in.
Last edit: 19 Jul 2019 21:59 by tommylight. Reason: More info
Moderators: newbynobi, HansU
Time to create page: 0.120 seconds
