Edit Jog Buttons
10 Aug 2020 14:42 #177837 by eighthaxis
Replied by eighthaxis on topic Edit Jog Buttons
Oops 2.8
10 Aug 2020 14:42 #177838 by eighthaxis
Does that me I have to totally reinstall Linuxcnc?
10 Aug 2020 18:40 #177846 by cmorley
Replied by cmorley on topic Edit Jog Buttons
You don't have to reinstall. just update.
How did you get linuxcnc?
10 Aug 2020 21:48 #177857 by eighthaxis
Awesome!
Thanks for your help.
I Installed Stretch then used the buildbot.
11 Aug 2020 15:47 #177943 by eighthaxis
I tried updating using the synaptic manager by hitting reload.
It downloaded new stuff I assume updates.
When I start GMOCCAPY now it still doesn't have A buttons.
Thanks for your help Chris,
Josh
The following user(s) said Thank You: newbynobi
11 Aug 2020 16:00 #177947 by newbynobi
Replied by newbynobi on topic Edit Jog Buttons
It may take some time, until build of is updated.
12 Apr 2021 13:08 #205723 by eighthaxis
I still can't get these jog buttons to appear.
Using version 2.8 with GMOCCAPY 3.0.8.2
Any suggestions?
15 May 2021 18:06 #208997 by eighthaxis
Does anyone know how to add the A- and A+ jog buttons to Gmoccapy?
16 May 2021 02:16 #209049 by newbynobi
You are still using the old version.
If you do update you should get 3.1.3.XX
How have you installed your linuxcnc?
If synaptic does not show updates fot linuxcnc, may be you haven't set the sources correct.
Norbert
17 May 2021 21:16 #209298 by eighthaxis
I am using Debian Stretch rt-preempt
When I try to upgrade with synaptic package manager I get this:Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
GPG error: linuxcnc.org stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEFThe repository 'linuxcnc.org stretch InRelease' is not signed.
I am trying to follow these directions:
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
Moderators: newbynobi, HansU
Time to create page: 0.732 seconds
