New error No control?? 5i25 7i77 Over Voltage!
- eighthaxis
- Thank you received: 8
29 Aug 2020 00:43 #179895
by eighthaxis
New error No control?? 5i25 7i77 Over Voltage! was created by eighthaxis
Iltereally changed nothing on the machine since it was last running fine and now I have a new error:
hm2/hm2_5i25.0: Smart serial card hm2_5i25.0.7i77.0.1 error = (28) Over
> Voltage
I am unable to turn on the machine. Halmeter doesn't seem to read the actual values going to the inputs.
If I hit e-stop on gmocappy it says it : Error: External ESTOP is set, could not change state.
I checked that all power supply voltages were proper and all was good.
Checked if any inputs were reading high voltages and found nothing.
Would this possibly be the Desktop PC's power supply voltage is too high.
> Voltage
- Thank you received: 5330
29 Aug 2020 01:25 #179897
Replied by PCW on topic New error No control?? 5i25 7i77 Over Voltage!
That error would indicate that the 7I77s field voltage was too high
- eighthaxis
29 Aug 2020 01:32 #179898
by eighthaxis
Replied by eighthaxis on topic New error No control?? 5i25 7i77 Over Voltage!
Field voltage is the same as it has always been.
4.88 and
23.99
4.88 and
23.99
29 Aug 2020 01:40 #179899
OK well for some reason the field I/O section of the 7I77 thinks the field
voltage is too high. Is it possible there is some debris or contamination
on the 7I77?
on the 7I77?
- eighthaxis
29 Aug 2020 04:10 #179909
by eighthaxis
I will look very closely tomorrow and be sure to blow it off.
Thanks for your help.
- newbynobi
- Thank you received: 394
29 Aug 2020 08:56 #179922
by newbynobi
Replied by newbynobi on topic New error No control?? 5i25 7i77 Over Voltage!
May be I am crazy, but I had a very similar problem on my laptop.
After I did a uname -a I realized, that my laptop did an update and it started with a non real time kernel.
Could you please check if you are running a preempt kernel?
Norbert
Norbert
- eighthaxis
29 Aug 2020 16:25 #179942
by eighthaxis
Thanks for your input Norbert.
Please excuse my ignorance of Linux but could you please give me a procedure to check if I am running a preempt kernel?
I did spend a little time trying to find out how but came back empty handed.
Also I will try updating Linuxcnc today as well as I still don't have all of the jog buttons on gmocappy.
- Clive S
- Thank you received: 486
29 Aug 2020 16:33 #179943
by Clive S
open a terminal and type uname -a
this should report back with what you are running and have RT in there
Replied by Clive S on topic New error No control?? 5i25 7i77 Over Voltage!
- eighthaxis
31 Aug 2020 17:12 #180191
by eighthaxis
This is what it said:
josh@Bostomatic:~$ uname -a
Linux Bostomatic 4.9.0-13-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
josh@Bostomatic:~$
josh@Bostomatic:~$
- Thank you received: 7488
31 Aug 2020 17:58 #180199
Replied by tommylight on topic New error No control?? 5i25 7i77 Over Voltage!
That is all good.
Can you measure the AC voltage on the 7i77 24V connector, then between + and - on that same connector and the machine GND for both AC and DC?
Moderators: newbynobi, HansU
Time to create page: 0.258 seconds
