How do I close a g-code file in Gmocapy?
29 Oct 2020 22:49 #187733 by rogerfries
Replied by rogerfries on topic How do I close a g-code file in Gmocapy?
It's not a stripped down version.
It's Mint XFCE with Linuxcnc pre installed.
Perhaps "stripped down" was not accurate, perhaps XFCE is considered a lightweight version? or am I still off track?
Following your instructions, I got Caja running and now I have the Date and time :)
I've got an extra PC I'm going to try and load Mint with cinnamon just to try
  • Moderator
  • Moderator
29 Oct 2020 22:56 - 31 Oct 2020 22:05 #187734 by tommylight
Replied by tommylight on topic How do I close a g-code file in Gmocapy?
Off topic - deleted
Last edit: 31 Oct 2020 22:05 by tommylight. Reason: off topic - deleted
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
29 Oct 2020 23:25 - 31 Oct 2020 20:52 #187735 by BeagleBrainz
Replied by BeagleBrainz on topic How do I close a g-code file in Gmocapy?
deleted off topic
Last edit: 31 Oct 2020 20:52 by BeagleBrainz.
  • BeagleBrainz
  • Visitor
  • Visitor
30 Oct 2020 10:09 - 31 Oct 2020 20:53 #187767 by BeagleBrainz
deleted off topic
Last edit: 31 Oct 2020 20:53 by BeagleBrainz.
31 Oct 2020 02:34 #187858 by rogerfries
Looking at Midnight commander takes me back to the 80's. Especially seeing the Hex editor. I remember using similar tools to cheat on PC games back in the day. time fly's I haven't had time for a computer game in years. Years ago I tried gaming on a PS3 and that twin stick controller didn't work for me. I'm a keyboard and mouse guy.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
31 Oct 2020 03:09 - 31 Oct 2020 20:53 #187859 by BeagleBrainz
deleted off topic
31 Oct 2020 10:24 #187880 by newbynobi
Replied by newbynobi on topic How do I close a g-code file in Gmocapy?
IMHO you are getting very, very, very off topic!
Gmoccapy has an integrated editor for files!
If you use an external editor and you save the file, you can use the reload button to get the newest version of the edited file.
All this works like a charm!
So all other stuff is not gmoccapy related, so please open an own thread to resolve that.
Thanks Norbert
31 Oct 2020 14:01 #187909 by rogerfries
Norbert,
Sorry. your right we've drifted way off topic. I'll sum up for any future reader hitting the last page button and let's close this thread.
I confirm LinuxCNC does not lock the file. As such Dropbox has no issue syncing the file and the reload button does the trick. My solution for ensuring I have the newest program is that I modified my Fusion 360 post processor to automatically add the created date/time to the comment section at the very top of the program so I can easily check after hitting the reload.
Thanks, Over and out.
Roger
  • BeagleBrainz
  • Visitor
  • Visitor
31 Oct 2020 20:54 #187944 by BeagleBrainz
Thanks Norbert
All off topics removed.
10 Nov 2024 13:45 #314187 by lkavan
Replied by lkavan on topic How do I close a g-code file in Gmocapy?
Hallo friends,
I would like to wake up this thread, becouse I have the same problem with LinuxCNC and cannot find solution.
When I open G code file from machine local disk, I can rewrite it without problem. For example, when I improve and generate same G code file from CAM. This is OK.
But when I have G code files on server Samba share, when file is opened in LinuxCNC, it is not possible to rewrite the file on samba share. I have found only one way to solve: Open other G code file in LinuxCNC, then previous file is unlocked and possible to rewrite. Then I have to open file I need again. But this really sucks!
Is there any solution how to unlock file on Samba share after it is loaded to LinuxCNC?
Thanx a lot!
Moderators: newbynobi, HansU
Time to create page: 0.134 seconds
