Gmoccapy with jog encoder
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Dec 2020 18:22 #191053 by RotarySMP
Gmoccapy with jog encoder was created by RotarySMP
I have my MPG connected similar in this example:
gnipsel.com/linuxcnc/hardware/mpg.html
... but with both joints and axis connections and enabled.
The whole signal change works in HALSHOW, with encoder movement changing all the counts through to those axis/joint pins, but no motion. The appropriate axis.x.jog-enable (or axis.z.jog-enable) are both connected and working, but no motion happens. I have done a fair bit of searching but find no reference to Gmoccapy specific pins or settings I need for this to work.
It make no difference whether the axis is homed or not. No motion.
I have attached the postgui HAL. Appreciate some assistance here. Thanks.
Mark
04 Dec 2020 20:05 #191061 by rodw
Replied by rodw on topic Gmoccapy with jog encoder
Mark, there is a step by step guide in my build (for a 7i76e)
forum.linuxcnc.org/show-your-stuff/32029...build?start=20#85279
Hope it helps.
  • RotarySMP
  • Platinum Member
  • Platinum Member
04 Dec 2020 20:47 #191068 by RotarySMP
Replied by RotarySMP on topic Gmoccapy with jog encoder
Hi Rod,
Thanks, but your HAL also ends with the encoder counts being netted to axis.[].jog-counts, which is what I also have. The encoder pulses are also working through to that point. That axis.[].jog-counts changes as I turn the encoder wheel. There is also an axis enabled, but nothing moves.
Mark
05 Dec 2020 10:29 #191114 by newbynobi
Replied by newbynobi on topic Gmoccapy with jog encoder
I am not at home, but out off memory:
- Did you set a jog scale / jog-increment?
I do not know the exact Hal pin name, but I remeber, when I added my first jog-wheel to my machine, about 15 years ago, I had exactly the problem you explained, due to not having set a jog increment with "setp axis-x-jog-increment 0.05" (something similar)
Norbert
05 Dec 2020 10:30 #191115 by rodw
Yes, norbert is reinforcing what PCW has said earlier and is what is missing from your config compared with mine.
05 Dec 2020 13:45 #191123 by newbynobi
Please find attached my config for my pendant based on a 7i73 connected to a 7i76e, My pendant does contain Jog increment selector, Axis selector an 100 ppr MPG and a security button, that mus be held pushed as long as the control is used.
This config may help as start point.
# 7i73 hal connections for the MPG     #
#        (c) Norbert Schechner         #
net jog-wheel-counts    joint.0.jog-counts   <=   hm2_7i76e.0.7i73.0.1.enc0.count
net jog-wheel-counts    joint.1.jog-counts
net jog-wheel-counts    joint.2.jog-counts
net jog-wheel-counts    axis.x.jog-counts
net jog-wheel-counts    axis.y.jog-counts
net jog-wheel-counts    axis.z.jog-counts
loadrt  mux2  names=jog-mode-sel
addf    jog-mode-sel    servo-thread
net   jog-scale-out     jog-mode-sel.in0  <=  gmoccapy.jog.jog-increment
setp  jog-mode-sel.in1  0.050
# need to get the jog mode
# Mode 0 alle Schritte werden ausgeführt, Mode 1 Drehen stopt, auch Axis stopt
net   jog-vel-mode  gmoccapy.jog.jog-inc-0  <=  jog-mode-sel.sel  <=  hm2_7i76e.0.7i73.0.1.input-07
net   jog-vel-mode  joint.0.jog-vel-mode
net   jog-vel-mode  joint.1.jog-vel-mode
net   jog-vel-mode  joint.2.jog-vel-mode
net   jog-vel-mode  axis.x.jog-vel-mode
net   jog-vel-mode  axis.y.jog-vel-mode
net   jog-vel-mode  axis.z.jog-vel-mode
# already connected cont_joging on jog vel mode selection
# net jog_cont       gmoccapy.jog.jog-inc-0  <=  hm2_7i76e.0.7i73.0.1.input-07
net jog_1000       gmoccapy.jog.jog-inc-1  <=  hm2_7i76e.0.7i73.0.1.input-06
net jog_0100       gmoccapy.jog.jog-inc-2  <=  hm2_7i76e.0.7i73.0.1.input-05
net jog_0010       gmoccapy.jog.jog-inc-3  <=  hm2_7i76e.0.7i73.0.1.input-04
net jog_0001       gmoccapy.jog.jog-inc-4  <=  hm2_7i76e.0.7i73.0.1.input-03
net jog_scale-out  joint.0.jog-scale  <=  jog-mode-sel.out
net jog_scale-out  joint.1.jog-scale
net jog_scale-out  joint.2.jog-scale
net jog_scale-out  axis.x.jog-scale
net jog_scale-out  axis.y.jog-scale
net jog_scale-out  axis.z.jog-scale
# loaded at estop_and_enable.hal
loadrt   and2 names=and_x,and_y,and_z
addf     and_x    servo-thread
addf     and_y    servo-thread
addf     and_z    servo-thread
# Freigabesignal erforderlich !
net freigabe            and_x.in0            <=     hm2_7i76e.0.7i73.0.1.input-15-not
net jog-x-selected      and_x.in1            <=     hm2_7i76e.0.7i73.0.1.input-14-not
net freigabe            and_y.in0
net jog-y-selected      and_y.in1            <=     hm2_7i76e.0.7i73.0.1.input-13-not
net freigabe            and_z.in0
net jog-z-selected      and_z.in1            <=     hm2_7i76e.0.7i73.0.1.input-12-not
net jog-x-enable        joint.0.jog-enable   <=     and_x.out
net jog-x-enable        axis.x.jog-enable
net jog-y-enable        joint.1.jog-enable   <=     and_y.out
net jog-y-enable        axis.y.jog-enable
net jog-z-enable        joint.2.jog-enable   <=     and_z.out
net jog-z-enable        axis.z.jog-enable
Or try just to add to your config something like:
setp joint.0.jog-scale 0.05
setp joint.1.jog-scale 0.05
setp joint.2.jog-scale 0.05
setp axis.x.jog-scale 0.05
setp axis.y.jog-scale 0.05
setp axis.z.jog-scale 0.05
the 0.05 is machine units per count!
Norbert
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Dec 2020 17:07 #191238 by RotarySMP
Thanks Rod and Norbert, I think my Gedenkfehler was I thought you have the external increment switch control the GUI buttons, and then the machine follows that.
I did get it working once Rod convinced me to ignore the GUI for this. Afterwards I also added a second set of nets so the one screen GUI follows along with what the phsical switches are doing.
Here is the current HAL:
forum.linuxcnc.org/media/kunena/attachments/2917/mpg.hal
I also now realise that I don't need the "Continuous" jog selection on the MPG. That is only really used with button jogging isnt it?
Mark
06 Dec 2020 20:58 #191249 by rodw
Great. You answered my question I asked on your video post. Yes continuous is handy on the screen but not used with a MPG. Just wind harder!
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Dec 2020 21:01 #191251 by RotarySMP
So now my engraving is both ugly and wrong :(.
06 Dec 2020 21:10 #191252 by rodw
Well you could pretend it was an Ugly 0 for off not a C and set it up so the jogs were disabled....
C = disabled sounds good!
Moderators: newbynobi, HansU
Time to create page: 0.132 seconds
