Changing modes on gmoccapy screen
- john11668
- Thank you received: 10
04 Feb 2021 11:22 #197638
by john11668
Changing modes on gmoccapy screen was created by john11668
Hi all
A bit of Backgound .
I have built and run a 3 axis mill on both Mach 3 and UCCNC.
Toward the end of last year I also converted a small Boxford TCL desktop lathe with new drivers and software and I have run it on Mach 3 (despite a bunch of limitations).
In an attempt to overcome the limitations on ratios, and screwcutting I am trying Linux CNC.
So I have installed Linux Mint along with its CNC element.
I have used stepconfig to generate a lathe profile using the Gmocappy screen and am in manual mode .
All is looking good . I can run the spindle and vary speed
I can jog slow and fast in both directions.
But I cannot seem to get into the auto screen , or the MDI screen to try running some code . The buttons for these functions are not illuminated so not available. I just cant see how to get them active .
So what am I missing????
While I am here, I have quite a few Gcode routines generated using wizards in Mach 3 previously.
Is it too optimistic to expect to them to run in Linux .
Thanks in anticipation,
- bevins
- Thank you received: 338
04 Feb 2021 11:47 #197641
by bevins
Replied by bevins on topic Changing modes on gmoccapy screen
Did you home the machine? Those modes wont be accessible until the machine is homed.
- john11668
04 Feb 2021 16:30 - 04 Feb 2021 16:31 #197659
by john11668
Replied by john11668 on topic Changing modes on gmoccapy screen
Thank you !
But where are the homing buttons ????
I dont see any on the manual screen
Last edit: 04 Feb 2021 16:31 by john11668.
- newbynobi
- Thank you received: 394
04 Feb 2021 17:49 #197666
by newbynobi
Replied by newbynobi on topic Changing modes on gmoccapy screen
Video basic usage
Please take a look at that video, so handling will be much clearer.
And please do not shout on me, as that video is very old and the design has change a little bit. I willl need to make all my videos with an actual release
Norbert
Norbert
- john11668
04 Feb 2021 18:12 #197668
by john11668
I was not shouting ,
I will own up to being a bit frustrated . Moving from Mach3 , It is a steep hill to climb and things are not intuitive until you have found the answer . I only got into this game about a year ago and Linux CNC within the last few weeks.
I actually did find the homing functions so am a bit further forward .
I will look at the video . See how I get on then .
- newbynobi
04 Feb 2021 22:18 #197688
by newbynobi
You will find out really quick, that open source have one big advantage:
You ask and you will get an answer.
The disadvantage is, that you may get several answers?
Have luck and enjoy gmoccapy
Norbert
Norbert
- john11668
05 Feb 2021 11:32 #197726
by john11668
So having overcome that obstacle. and with the vids generally in multi axis mill mode whilst I am applying it to a lathe it is not always straight forward to apply the info there .
Foe example In lathe mode I have dual readout for radius and diameter and a simple instruction in code seems to be interpreted as a radius instruction if I use MDI. Can I place my software into diameter mode (which I generally prefer ) or do I have to switch using code
- john11668
05 Feb 2021 11:34 #197728
by john11668
I also have queries on file handling bur will start a new thread on that.
- newbynobi
05 Feb 2021 22:50 #197789
by newbynobi
In lathe mode, gmoccapy will react to G7 G8 changes and the corresponding DRO will be highlighted or better told the none used DRO will have a Grey bagground. A klick on the axis letter however shout show the dialog to set a value to DRO and klick on the numbers of the DRO will toggle between absolut, relativ and distance to go mode.
File handling will be ecual for lathe or mill, what are the questions you have?
Norbert
Norbert
- john11668
06 Feb 2021 00:08 #197795
by john11668
I started a new thread Norbert
forum.linuxcnc.org/38-general-linuxcnc-q...rt-into-linux-cncfro
Norbert
Moderators: newbynobi, HansU
Time to create page: 4.084 seconds
