Axis buttons missing ?
28 Feb 2021 11:36 #200392 by mucy007
Axis buttons missing ? was created by mucy007
Hello, Dear Linuxcnc comunity.
Does anyone know the reason for this problem, when i use
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
No axis keys are visible in Linuxcnc, machine is ON, and i am able to control spindle.
If i use
[KINS]
JOINTS = 4
Then the axis keys are visible, but immediatly after trying to move axis machine goes into Emergency stop with error: JOINT (x) following error
I would like to know if somebody already dealth with sommething like that and how to fix this?
Thank you
28 Feb 2021 12:35 #200398 by Clive S
Replied by Clive S on topic Axis buttons missing ?
As a start re:
HOME_INGORE_LIMITS = YES remove this SH compensation STEPGEN_MAXACCEL should be 100% larger
and
HOME_SEQUENCE = 2 for the Y this needs to be a -ve number ie -2 for both instances this is to make them both synced
The following user(s) said Thank You: mucy007
28 Feb 2021 14:06 #200420 by newbynobi
Replied by newbynobi on topic Axis buttons missing ?
You may have a llok at linuxcnc-dev/configs/sim/gmoccapy/non_trivial_kinematics/Gantry/gantry_mm.ini as an example.
02 Mar 2021 13:26 #200783 by mucy007
Replied by mucy007 on topic Axis buttons missing ?
Hello Togehter,
thank you for your help, now it is working propperly.
13 Mar 2021 06:14 #202059 by Creative25
Replied by Creative25 on topic Axis buttons missing ?
I had the same problem.
If I comment out this line
kinstype=BOTH
Then it works fine.
As soon as I edit something with PNCconf
It gets overwritten and buttons disappear how do Change this permanently?
13 Mar 2021 09:12 #202076 by Clive S
kinstype=BOTH
Then it works fine.
Once you have used Pncfig then you have to hand edit the files manually in the HAL and INI files
You will find the ( kinstype=BOTH) in the INI file if you don't require it put a hash (#) before it or just delete the line
13 Mar 2021 12:09 #202090 by newbynobi
Hallo,
thanks for reporting, that is an bug, I need to fix!
Strange is, you can home the machine and the button appear. Switching then to joint mode results in not having any jog button.
By the way, why someone wants to use Joints mode on a Gantry? It is dangerous jogging only Y1, or are there reasons to do that?
I have not rebuild my gantry, will do this this year, but mine has only one Motor for Y, moving both Y ball screws with a belt.
Norbert
13 Mar 2021 12:44 #202091 by Creative25
One problem I picked up is this. When jogging only one y axis moves,
When I run a program both motors y and y2 are moving. Has this to do with this bug?
13 Mar 2021 13:17 #202092 by newbynobi
@creative25,
no! If your config has negative numbers for home sequence, you not even be allowed to jog a joint Y or Y2 if that joints are not homed.
Have you in your INI HOME_SEQUENCE = -2 für both Y joints?
This could be a typical double Y joint config for a gantry:
[AXIS_Y]
MAX_VELOCITY = 80
MAX_ACCELERATION = 200
MIN_LIMIT = 0
MAX_LIMIT = 2000
[JOINT_1]
TYPE = LINEAR
MAX_VELOCITY = 200
MAX_ACCELERATION = 1000
MIN_LIMIT = 0
MAX_LIMIT = 2000
HOME = 0.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = -2
[JOINT_2]
TYPE = LINEAR
MAX_VELOCITY = 200
MIN_LIMIT = 0
MAX_LIMIT = 2000
HOME = 0.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = -2
Norbert
13 Mar 2021 15:17 #202101 by Creative25
I don’t have any of those yet.
Probably because I did not install any limit switches. So basically I first have to install at least the two home switches for y axis before I can do homing and jogging the Y axis?
Moderators: newbynobiHansU
Time to create page: 0.120 seconds
