Axis buttons missing ?
- newbynobi
- Thank you received: 394
14 Mar 2021 15:46 #202219
by newbynobi
Replied by newbynobi on topic Axis buttons missing ?
I pushed a fix to 2.8 branch!
So now even if it makes no sense in identity kinematics you will get the joints button if kintype BOTH is found in the INI.
A better solution is a correct INI file
Norbert
Norbert
- Creative25
- Thank you received: 11
14 Mar 2021 16:22 #202225
by Creative25
Replied by Creative25 on topic Axis buttons missing ?
Thanks so now how do I get the fix?
Updating linuxcnc from Synaptics or commandline?
- newbynobi
14 Mar 2021 21:35 #202264
by newbynobi
If you installed from buildbot you will get the patch within a few days, if you installed from a CD it might need some more time as a new build has to be made, if you installed from source, just pull the latest 2.8 release and recompile.
Norbert
Norbert
- Creative25
15 Mar 2021 08:25 #202317
by Creative25
So basically this fix makes buttons work if ini file is not correct?
So to have a useful machine you have to get the ini file correct anyway?
- newbynobi
15 Mar 2021 22:31 - 15 Mar 2021 22:33 #202428
by newbynobi
Exactly,
if you have a trivial kinematics, so one joint is one axis and all are ordered in kartesian coordination, it does not make sense to have joint jogging, that is why I decided not to show joint jogging buttons if INI sayes trivkins.
I did not take care about someone who added kinstype=Both. This entry forces the GUI now to show the joints button, even if does not make sense at all. If the user press a joint button of Joint1 being y1 he will get an error, as it is not allowed to jog only one side of an gantry.
By the way, if you do not have any jog button and you home your machine, you will see, that the axis jog button do appear like a miracle
So this an unneeded fix just to not disturb the users.
Norbert
Norbert
Last edit: 15 Mar 2021 22:33 by newbynobi.
Moderators: newbynobi, HansU
Time to create page: 0.213 seconds
