size of default preview screen.
- john11668
- Thank you received: 10
19 Jun 2021 14:40 #212404
by john11668
size of default preview screen. was created by john11668
I am trying a 10"touch screen which has been lent to me .
I quite like it but wonder if I can reduce the size of the preview screen to give more space for the buttons .
Currently the preview seems to be taking up about 60% of the screen so buttons are small and I am having to use a stylus for them.
I know I can enlarge the preview if I wan more detail . 10" screen seems to fit nicely on a small lathe
- newbynobi
- Thank you received: 394
20 Jun 2021 20:01 #212510
by newbynobi
Replied by newbynobi on topic size of default preview screen.
What is the native resolution of the screen?
Buttons will have 56 Pixel hight on default, the preview will be smaller in normal resolution.
Most probably the screen will have native resolution of 800x480 and will not fit the needs for gmoccapy
May be you use a non native resolution and that's why the buttons are so small
- john11668
20 Jun 2021 21:46 #212518
by john11668
Replied by john11668 on topic size of default preview screen.
Have tried various resolutions .
The recommended , which I think is 1024/768 leaves the bottom buttons obscured by the menu bar .
So I take it I cant reduce items or shift them about , other than by altering resolution. Problem seems to be that higher resolutions enlarge the preview . but leave the buttons at around the same size
- Thank you received: 7468
20 Jun 2021 22:08 #212521
Replied by tommylight on topic size of default preview screen.
You can enable the "auto hide" feature of the menu bar, or panel.
- john11668
21 Jun 2021 08:49 - 21 Jun 2021 09:43 #212545
by john11668
I did look for that facility but did not see it .
Can you guide me to it please
Last edit: 21 Jun 2021 09:43 by john11668.
- john11668
21 Jun 2021 18:08 #212571
by john11668
Found it!
21 Jun 2021 20:40 #212593
To late !
- john11668
21 Jun 2021 21:18 #212598
by john11668
Never too late tommy !
- john11668
22 Jun 2021 11:16 #212660
by john11668
But is there no way to reduce he size of the preview window ?
- newbynobi
30 Jun 2021 20:27 #213366
by newbynobi
Only changing code in gmoccapy and modifiing the glade panel. Post a screen shot please
Moderators: newbynobi, HansU
Time to create page: 0.199 seconds
