LCNC 2.8 - Language bugs
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Jul 2022 19:29 - 07 Jul 2022 20:10 #246529 by zz912
Replied by zz912 on topic Translate Tooltip Home button dont work
/home/pi/LinuxCNC/linuxcnc-2.8/src/emc/usr_intf/gmoccapy/gmoccapy.glade
line 8600:
                    <property name="tooltip_text" translatable="yes">Move to parrent directory</property>
Please change parrent =>parent
line 8630:
                    <property name="tooltip_text" translatable="yes">Select the previos file</property>
Please change previos => previous
Edit: I made Pull requesthttps://github.com/LinuxCNC/linuxcnc/pull/1809
Last edit: 07 Jul 2022 20:10 by zz912.
04 Jul 2022 18:22 - 04 Jul 2022 18:25 #246590 by HansU
Replied by HansU on topic Translate Tooltip Home button dont work
Yes I can commit your fixes to Github, but only in a few weeks.
The string "commands" in the MDI history is currently not translatable.
Last edit: 04 Jul 2022 18:25 by HansU.
  • zz912
  • Platinum Member
  • Platinum Member
05 Jul 2022 08:34 - 05 Jul 2022 08:35 #246632 by zz912
Thank you. A few weeks is a good term in the open-source world.
Colleagues said you are on holiday. I wish you a wonderful holiday.
Last edit: 05 Jul 2022 08:35 by zz912.
  • zz912
  • Platinum Member
  • Platinum Member
05 Jul 2022 13:13 #246645 by zz912
I didn't find a way to translate.
  • zz912
  • Platinum Member
  • Platinum Member
13 Jul 2022 08:40 #247215 by zz912
Replied by zz912 on topic LCNC 2.8 - Language bugs
I managed to fix some errors with the help of the members here.
I learned how to make a pull request on Github thanks to it.
Would anyone be willing to take a look at the remaining bugs?
forum.linuxcnc.org/gmoccapy/46206-transl...ton-dont-work#246506
forum.linuxcnc.org/gmoccapy/46206-transl...ton-dont-work#246507
forum.linuxcnc.org/gmoccapy/46206-transl...work?start=10#246645
27 Jul 2022 15:13 - 27 Jul 2022 15:15 #248426 by HansU
Replied by HansU on topic LCNC 2.8 - Language bugs
This should work when editing the string in src/po/gmoccapy/cs.po
#: dialogs.py:111 dialogs.py:126 dialogs.py:140
msgid "Operator Message"
These are just strings you can ignore while translating. It doesn't matter what is inside this string, as it is only a placeholder that's being overwritten.
I fixed this in 2.8 now. Look for the string "Exit and discard changes?"
Last edit: 27 Jul 2022 15:15 by HansU.
The following user(s) said Thank You: zz912
  • zz912
  • Platinum Member
  • Platinum Member
27 Jul 2022 20:03 #248454 by zz912
Exit and discard changes - works.
But I still have problem with message "Operator Message"
I dont know, what should be wrong.
In src/po/gmoccapy/cs.po is:
#: emc/usr_intf/gmoccapy/dialogs.py:111 emc/usr_intf/gmoccapy/dialogs.py:126
#: emc/usr_intf/gmoccapy/dialogs.py:140
msgstr "Zpráva pro operátora"
  • zz912
  • Platinum Member
  • Platinum Member
27 Jul 2022 20:13 #248456 by zz912
Now Operator Message works.
It must be changed in:
src/po/cs.po
  • Moderator
  • Moderator
27 Jul 2022 22:06 #248476 by tommylight
Replied by tommylight on topic LCNC 2.8 - Language bugs
hey, Czech language ! :)
I can read and understand that easily.
  • zz912
  • Platinum Member
  • Platinum Member
27 Jul 2022 22:16 #248477 by zz912
Some people will love me for Czech language.
Some people will hate me for Czech language. Turn off Czech language is not easy for no programator.
Moderators: newbynobiHansU
Time to create page: 0.324 seconds
