Duplicate settings in Pref File
3 years 2 weeks ago #283074 by CNCGOOS
Hello All,
I am just using LCNC 2.9 with GMOCCAPY.
Often i get a error during Start of the program.
The problem is then that de folowing parematers are Duplicate in the Pref file
system_name_Tool = Tool
system_name_G5x = G5x
system_name_Rot = Rot
system_name_G92 = G92
system_name_G54 = G54
system_name_G55 = G55 0 pos vacuumtafel systainer
system_name_G56 = G56
system_name_G57 = G57
system_name_G58 = G58
system_name_G59 = G59 tbv Tool change
system_name_G59.1 = G59.1
system_name_G59.2 = G59.2
system_name_G59.3 = G59.3
Now i am using LCNC 2.9 that is e problem. before in LCNC 2.8.4 thet was not e problem
What can i do to get rid of that problem. now i am deling the second blok of the same parameters.
3 years 2 weeks ago #283076 by HansU
Can you post a complete file which is erroneous?
3 years 2 weeks ago #283108 by CNCGOOS
[DEFAULT]
dro_digits = 3
dro_size = 28
abs_color = #0000FF
rel_color = #000000
dtg_color = #FFFF00
homed_color = #00FF00
unhomed_color = #FF0000
enable_dro = False
scale_jog_vel = 1000.0
scale_spindle_override = 1
scale_feed_override = 1.5
scale_rapid_override = 1.5
spindle_bar_min = 5000.0
spindle_bar_max = 36000.0
turtle_jog_factor = 25
hide_turtle_jog_button = False
unlock_code = 123
toggle_readout = True
spindle_start_rpm = 4800.0
blockheight = 0.0
open_file =
screen1 = maximized
x_pos = 40
y_pos = 30
width = 979
height = 750
use_toolmeasurement = False
gtk_theme = Follow System Theme
grid_size = 1.0
view = z
mouse_btn_mode = 4
hide_cursor = False
hide_tooltips = False
system_name_tool = Tool
system_name_g5x = G5x
system_name_rot = Rot
system_name_g92 = G92
system_name_g54 = G54
system_name_g55 = G55 0 pos vacuumtafel systainer
system_name_g56 = G56
system_name_g57 = G57
system_name_g58 = G58
system_name_g59 = G59 tbv Tool change
system_name_g59.1 = G59.1
system_name_g59.2 = G59.2
system_name_g59.3 = G59.3
jump_to_dir = /home/joost
show_keyboard_on_offset = False
show_keyboard_on_tooledit = False
show_keyboard_on_edit = False
show_keyboard_on_mdi = False
x_pos_popup = 45.0
y_pos_popup = 70.0
width_popup = 250.0
max_messages = 10
message_font = sans 10
use_frames = True
reload_tool = True
blockdel = False
show_offsets = False
show_dtg = False
view_tool_path = True
view_dimension = True
run_from_line = no_run
unlock_way = no
show_preview_on_offset = False
use_keyboard_shortcuts = False
tool_in_spindle = 2
offset_axis_z = 3.0
offset_axis_y = 0.25
offset_axis_x = -2.0
probeheight = -1.0
searchvel = 75.0
probevel = 10.0
3 years 2 weeks ago - 3 years 2 weeks ago #283128 by newbynobi
So an error causes that duplicate settings, what kind of error?
Norbert
Last edit: 3 years 2 weeks ago by newbynobi.
3 years 2 weeks ago #283136 by CNCGOOS
the Added picture is te error during the boot of LCNC
3 years 2 weeks ago #283240 by newbynobi
Thats the error after you got the double entries, I understood that after an error the double entries are created.
This way it will be difficult to find :-(
Moderators: newbynobi, HansU
Time to create page: 0.066 seconds
