Duplicate settings in Pref File
3 years 1 week ago #283612 by CNCGOOS
what kind of info or screens do you han need ?
2 years 11 months ago #284925 by HansU
Can you try to figure out in which case  duplicate entries are added to the pref file? Does it happen when you make changes to the setttings or just running a job? Or does is seem to happen more like random?
I tried to reproduce this, but didn't get those duplicate entries.
2 years 6 months ago #297514 by pistrix
I have exactly the same problem but I don't know what causes it. It seems random. So you say that the error causes double entries and not vice versa? I thought it is the opposite: because of the double entries, linuxcnc returns the error. I am confused.
2 years 4 months ago #303324 by neerajbagi
I am also facing the same issue. It seems to me that the duplication of entries in .pref file is happening after the completion of a job, and shutting down the software/ system. It is also very random. Sometimes it happens, sometimes it doesn't.
I clearly remember that this error started occurring only after I changed the theme in the settings tab.
2 years 4 months ago #303334 by cmorley
Are you using any embedded programs?
If you erase the entry does it come back?
You must only hand edit preferences when Gmoccapy is not running.
The ones with a capital letter on the end word are from Gmoccapy:
system_name_G54 = G54
It seems the system entries preferences are checked at initialization and when the offsets tab is closed.
2 years 4 months ago #303348 by neerajbagi
No. Not using any embedded programs.
Yes. After erasing the duplicate entry, it comes back only after shutting down Linuxcnc.
I am editing the preference file only when Gmoccapy isn't running.
And the occurrence of this is very very random. At times, the duplication doesn't happen.
Moderators: newbynobi, HansU
