Duplicate settings in Pref File
2 years 4 months ago #303369 by cmorley
What version of linuxcnc are you using and can you post your INI file?
2 years 4 months ago - 2 years 4 months ago #303377 by neerajbagi
Using Linuxcnc 2.9.2. I am attaching the INI.
I have another system that runs on Linuxcnc 2.8.4, and it hasn't encountered this issue even once. Not sure if I am doing something wrong on the previous system.
File Name: meukron_li...6-19.ini
File Size:5.8 KB
Last edit: 2 years 4 months ago by neerajbagi.
2 years 4 months ago #303382 by cmorley
What does the embedded gladevcp panel do?
2 years 4 months ago #303385 by cmorley
Also do you ever run a different version of GMoccapy in the same folder?
Ie it may record things in the preference file.
2 years 4 months ago #303386 by cmorley
How about translations? Does your system use translated text?
2 years 4 months ago #303396 by neerajbagi
The embedded panel is only for the zeroing of XYZ axes. No other functionality is being used with gladevcp.
I didn't run a different version of linuxcnc in the same folder, but I have copied my previous folder from the 2.8.4 machine to the configs directory, primarily to make similar changes to the .ini and .hal files.
No translations for text are being used.
Moderators: newbynobi, HansU
Time to create page: 0.116 seconds
