Gmoccapy - spindle restarts at program stop
2 years 1 week ago #312846 by MennilTossFlykune
I assume this is the same issue:
2.10.0-pre0-3740-g5ec17ac2b8
The only way I've been able to reproduce it consistently is by starting and then stopping immediately, but when I recorded this video it happened without fail.
I think it's related to how the state is restored from a state tag after an abort(?).
If I comment out emcTaskStateRestore(); at line 2078 in emctaskmain.cc the spindle doesn't restart.
2 years 1 week ago #312871 by MennilTossFlykune
Here it is in gmoccapy:
If I abort almost immediately with the ESC key, the spindle stays on.
Does not happen with emcTaskStateRestore(); commented out.
2 years 1 week ago #312881 by Aciera
Does this happen in QtDragon for you as well?
2 years 1 week ago - 2 years 1 week ago #313046 by MennilTossFlykune
Yes. I have a real machine with QtDragon where this has been happening for some time now but I thought it was caused by something else until I noticed it happening in a simulation as well. I did some more experimenting and I discovered that if I have a G64 with a large P value, like 1 for example, the spindle doesn't restart. The smaller the P value is the further into a program it has to run before the spindle doesn't restart after an abort.With a G61 the spindle always restarts. I've only used 3D_Chips.ngc to test it.
I think this is related to what's happening:
github.com/LinuxCNC/linuxcnc/issues/579#issuecomment-640557582
This sure does sound related to #865 and #882, where readahead segments aren't dropped during task abort, and get flushed into the queue by commands following the abort: the ON_ABORT_COMMAND in this case, and the restored state tag in the case of #865.
However, in my quick test, I couldn't tickle the bug in the 2.8 branch by adding the ON_ABORT_COMMAND from @sheetcam's config. Anyway, if it is the same problem, hopefully #882 will fix it.
Last edit: 2 years 1 week ago by MennilTossFlykune.
2 years 1 week ago #313062 by Aciera
If it's related to that issue then we should expect this to also show up using the Axis GUI. Are you seeing it in Axis as well?
2 years 1 week ago #313065 by MennilTossFlykune
Yes. I tested it now on 2.10 RIP and it seems to behave like how I described.
Moderators: newbynobi, HansU
Time to create page: 0.265 seconds
