Gmoccapy - spindle restarts at program stop
2 years 1 week ago #313070 by Aciera
Yes, I can reproduce this as well (took me a few tries but eventually I also got the spindle to still run when the program stopped):
Python stat:
acceleration    100.0 active_queue    0 actual_position    0.0000   0.0000   -0.1561 adaptive_feed_enabled    False ain    0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000 angular_units    1.0000 aout    0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000   0.0000 axis_mask    7 block_delete    True call_level    0 command    - current_line    2613 current_vel    0.0000 cycle_time    0.001 debug    0 delay_left    0.0 din    False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False distance_to_go    0.0000 dout    False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False False dtg    0.0000   0.0000   0.0000 echo_serial_number    126 enabled    True estop    0 exec_state    done feed_hold_enabled    True feed_override_enabled    True feedrate    1.0 file    /tmp/tmput72cao1/3D_Chips.ngc flood    0 g5x_index    1 g5x_offset    0.0000   0.0000   -1.9685 g92_offset    0.0000   0.0000   0.0000 gcodes    G1 G17 G40 G21 G90 G94 G54 G49 G99 G64 G97 G91.1 G8 homed    1 1 1 ini_filename    /home/user/git/linuxcnc-master-official/configs/sim/axis/axis.ini inpos    True input_timeout    False interp_state    idle interpreter_errcode    0 joints    3 kinematics_type    identity limit    0 0 0 linear_units    0.0394 max_acceleration    100.0000 max_velocity    5.0000 mcodes    M3 M8 M48 M53 M0 misc_error    (0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0) mist    0 motion_id    0 motion_line    0 motion_mode    teleop motion_type    none num_extrajoints    0 optional_stop    True paused    False pocket_prepped    1 position    0.0000   0.0000   -0.1561 probe_tripped    False probe_val    0 probed_position    0.0000   0.0000   0.0000 probing    False program_units    mm queue    0 queue_full    False queued_mdi_commands    0 rapidrate    1.0 read_line    0 rotation_xy    0.0000 settings    2614.0000 1000000.0000 1600.0000 0.1000   0.1000 spindle    0                brake 1 0            direction 0 0              enabled 1 0     override_enabled True 0                speed 1600.0 0             override 1.0 0                homed False 0         orient_state 0 0         orient_fault 0 1                brake 1 1            direction 0 1              enabled 0 1     override_enabled False 1                speed 0.0 1             override 1.0 1                homed False 1         orient_state 0 1         orient_fault 0 2                brake 1 2            direction 0 2              enabled 0 2     override_enabled False 2                speed 0.0 2             override 1.0 2                homed False 2         orient_state 0 2         orient_fault 0 3                brake 1 3            direction 0 3              enabled 0 3     override_enabled False 3                speed 0.0 3             override 1.0 3                homed False 3         orient_state 0 3         orient_fault 0 4                brake 1 4            direction 0 4              enabled 0 4     override_enabled False 4                speed 0.0 4             override 1.0 4                homed False 4         orient_state 0 4         orient_fault 0 5                brake 1 5            direction 0 5              enabled 0 5     override_enabled False 5                speed 0.0 5             override 1.0 5                homed False 5         orient_state 0 5         orient_fault 0 6                brake 1 6            direction 0 6              enabled 0 6     override_enabled False 6                speed 0.0 6             override 1.0 6                homed False 6         orient_state 0 6         orient_fault 0 7                brake 1 7            direction 0 7              enabled 0 7     override_enabled False 7                speed 0.0 7             override 1.0 7                homed False 7         orient_state 0 7         orient_fault 0 spindles    1 state    rcs_done task_mode    manual task_paused    0 task_state    on tool_from_pocket    1 tool_in_spindle    1 tool_offset    0.0000   0.0000   0.0000 toolinfo    <built-in method toolinfo of linuxcnc.stat object at 0x562b15b3de50> velocity    0.0
2 years 1 week ago #313071 by Aciera
Has this been filed as an issue on github yet?
2 years 1 week ago #313087 by MennilTossFlykune
I'm still not sure exactly how to describe this issue, I can only demonstrate it.
You can see here how G61/G64 are related to this:
The larger the P value the further into the program the interpreter will be able to read.
If the interpreter has reached a queuebuster when the program is aborted, the interpreter state and machine state will be synched properly(?)
2 years 1 week ago #313098 by Aciera
Hm, I'm afraid I don't. You are inserting a tool change which I believe is a queue buster. I'm not sure how the P value in G64 would influence how far ahead the interpreter read ahead is. Could you elaborate a bit?
2 years 1 week ago - 2 years 1 week ago #313101 by Aciera
Looks like this might be limited to spindle speed and direction pins not consistently reacting to a program stop as 'spindle.0.on' seems to always clear.
Last edit: 2 years 1 week ago by Aciera.
The following user(s) said Thank You: tommylight, Serg452
1 year 7 months ago #325035 by HalaszAttila
Hello, is there any progress to be made in solving the problem? I think it is very risky (especially on a lathe) if the spindle can start unexpectedly, but it can also cause problems on milling machines with tool changers.
Moderators: newbynobi, HansU
Time to create page: 0.159 seconds
