Auto tool measurment files
- Thank you received: 2163
15 Feb 2024 17:37 #293423
Replied by Aciera on topic Auto tool measurment files
Use the 'hal configuration' tool in the gmoccpy gui (button on the bottom right of the settings page).
select the 7i96s in the left hand window and follow the tree to the inputs. You should see the available input pins and the inverted pins as well.
Might as well check the signal changes in the 'watch' tab in the right window when the probe is activated.
The following user(s) said Thank You: al_sur_dionisis
- al_sur_dionisis
15 Feb 2024 17:50 - 15 Feb 2024 17:55 #293424
by al_sur_dionisis
Replied by al_sur_dionisis on topic Auto tool measurment files
Everything works fine
Thanks ACIERA!!!
Longlive the linuxcnc comunity!!!
Next step is to find away to have G54 coordinates and not absolute for tool change but I think this is too much.
The reason is that my CNC gantry is not too plan. So the nearest is done the tool measurment to my workpiece the best result I have.
Thanks ACIERA!!!
Last edit: 15 Feb 2024 17:55 by al_sur_dionisis.
Moderators: newbynobi, HansU
Time to create page: 0.098 seconds
