gmoccapy pins
07 Aug 2024 11:32 - 07 Aug 2024 11:40 #307169 by Moutomation
Replied by Moutomation on topic gmoccapy pins
It's very nice, it works very well, thank you very much.
Last edit: 07 Aug 2024 11:40 by Moutomation.
07 Aug 2024 11:42 #307170 by Aciera
Replied by Aciera on topic gmoccapy pins
File path is defined in this line in the python code of the user component above:
file_path = 'file.txt'
eg change to:
file_path = '/home/<user_name>/<your_path>/<your_file>'
The following user(s) said Thank You: Moutomation
07 Aug 2024 12:45 #307172 by Moutomation
thaks a lot
09 Aug 2024 07:40 #307299 by Moutomation
I created a folder shared between Windows and Linux. I saved the File.txt file in this folder in Windows. When I open the file.txt file on the Windows side, make changes to it and save it, the g code changes directly in Linuxcnc. Everything is fine up to this point. However, while the Python code is running, I cannot send the new file.txt file with the same name to this folder, I receive a no permission warning. If I close Linuxcnc and the Python code does not work, I can replace the new file with the old file. There is no problem in going into the file.txt file, making changes and saving it. There is only a problem when replacing the old file.txt with the new file.txt.
I tried to do it, I tried to add time to the Python code, but I couldn't. I don't know if adding time is a solution anyway.
09 Aug 2024 08:18 #307302 by Aciera
Not sure as I cannot test updating the file remotely but if you want to add a time delay between file checks you could try this modified python component.
#!/usr/bin/env python3
import os
import time
import hal
import linuxcnc
h = hal.component("file-check")
h.newpin("file-changed", hal.HAL_BIT, hal.HAL_OUT)
h.ready()
# create a connection to the status channel
s = linuxcnc.stat()
# this is the file being checked for updates (example looks for 'file.txt' in the config folder)
# wait time in milliseconds between file checks
check_interval = 5000
# length of output pulse in milliseconds
pulse_length = 1000
last_modified = os.path.getmtime(file_path)
check_timer_start = round(time.time()*1000)
h['file-changed'] = False
try:
    while 1:
        s.poll()
        # see if it is time to check the file
        if round(time.time()*1000) >= check_timer_start + check_interval:
            # we don't want to reload when program is running
            if s.task_mode == 2 and s.state == 1: # ie AUTO-mode and 'RCS_DONE'
                current_modified = os.path.getmtime(file_path)
                if current_modified != last_modified:
                    print("File has changed!")
                    h['file-changed'] = True
                    pulse_timer_start = round(time.time()*1000)
                    last_modified = current_modified
                if h['file-changed'] and pulse_timer_start + pulse_length <= round(time.time()*1000):
            # restart the timer for file checking
except KeyboardInterrupt:
    raise SystemExit
09 Aug 2024 14:44 - 09 Aug 2024 14:45 #307363 by Moutomation
When I go into the file.txt file, make corrections manually and save it, there is no problem. But I cannot replace it with a new file.txt file, I get the error that the file is in use.
While the python code is running it won't let me replace it with a file of the same name
Last edit: 09 Aug 2024 14:45 by Moutomation.
10 Aug 2024 06:49 #307403 by Moutomation
I think I found a solution. When Linuxcnc first opens, we must wait for a while and delete the file.txt file with Python. Then we must constantly check whether the file exists. Once the file is in the folder, we must activate the change button.
10 Aug 2024 08:18 #307405 by Aciera
This will delete the file on startup:
import os
import time
import hal
import linuxcnc
h.ready()
s = linuxcnc.stat()
# length of output puls in milliseconds
pulse_length = 1000
# delete the file if it already exists
if os.path.exists(file_path):
   print("The file exists, deleting it.")
   os.remove(file_path)
else:
  print("The file does not exist")
try:
    while 1:
        s.poll()
        if round(time.time()*1000) >= check_timer_start +check_interval:
    raise SystemExit
10 Aug 2024 08:46 - 10 Aug 2024 08:48 #307408 by Moutomation
Last edit: 10 Aug 2024 08:48 by Moutomation.
10 Aug 2024 19:55 #307435 by rodw
Replied by rodw on topic gmoccapy pins
It seems like you guys need to build a folder watcher,
The operating system has methods to do something if the contents of a folder changes.
Python has an interface to this. There are a number of examples on the web. Here is one to get you going
thepythoncorner.com/posts/2019-01-13-how...-filesystem-changes/
The following user(s) said Thank You: Aciera, Moutomation
Moderators: newbynobi, HansU
Time to create page: 0.224 seconds
