gmoccapy pins
- Moutomation
- Thank you received: 11
11 Aug 2024 17:37 #307485
by Moutomation
Replied by Moutomation on topic gmoccapy pins
The code written by Aciera works, but I'm having problems with permissions right now. I created a common folder between Windows and Linux. I can't give permission to this folder on the lşnux side, even though I used the chmod 777 command.
- Moutomation
12 Aug 2024 10:20 #307530
by Moutomation
Aciera, I thank you very much again. The code you wrote works perfectly. I was only having problems because I was trying to do this in the shared folder. I added the following code to the python code and copied the file to another location. Everything is OK now.
import shutil
# Source path
source = "/home/User/Documents/file.txt"
# Destination path
destination = "/home/User/Documents/newfile/file.txt"
# Copy the content of
# source to destination
shutil.copyfile(source, destination)
import shutil
# Source path
# Destination path
- Moutomation
12 Aug 2024 11:01 #307537
by Moutomation
We are doing a project by spending a lot of time, writing macros, making a plc program. ethercat.xml file,hal files, how can we protect them from our competitors.
- Moutomation
20 Aug 2024 05:54 #308189
by Moutomation
Currently, the Windows folder is shared and we can see this folder in Linux. However, sometimes when Linux starts faster than Windows, Windows does not open and the Python code gives an error because it cannot find this file and Linuxcnc does not open. How can we do something here? For example, if it cannot find the file, it does not give an error and Linux starts. Can we do this? Having Linuxcnc open without errors is enough for me. It should be enough that it does not prevent Linuxcnc from starting.
If there is a file, it should read it. If there is no file, it should not prevent Linuxcnc from starting without giving an error.
- Moutomation
20 Aug 2024 05:56 #308190
by Moutomation
#!/usr/bin/env python3
import os
import time
import hal
import linuxcnc
import shutil
source = "/mnt/taglio/CutDocument.txt"
destination = "/mnt/CutDocument.txt"
h = hal.component("file-check")
h.newpin("file-changed", hal.HAL_BIT, hal.HAL_OUT)
h.ready()
# create a connection to the status channel
s = linuxcnc.stat()
# this is the file being checked for updates (example looks for 'file.txt' in the config folder)
file_path = '/mnt/taglio/CutDocument.txt'
# wait time in milliseconds between file checks
check_interval = 1000
# length of output pulse in milliseconds
pulse_length = 1000
last_modified = os.path.getmtime(file_path)
check_timer_start = round(time.time()*1000)
h = False
try:
while 1:
s.poll()
# see if it is time to check the file
if round(time.time()*1000) >= check_timer_start + check_interval:
# we don't want to reload when program is running
if s.task_mode == 2 and s.state == 1: # ie AUTO-mode and 'RCS_DONE'
current_modified = os.path.getmtime(file_path)
if current_modified != last_modified:
print("File has changed!")
h = True
pulse_timer_start = round(time.time()*1000)
last_modified = current_modified
if h and pulse_timer_start + pulse_length <= round(time.time()*1000):
h = False
# restart the timer for file checking
except KeyboardInterrupt:
raise SystemExit
import os
import time
import hal
import linuxcnc
import shutil
h.ready()
s = linuxcnc.stat()
pulse_length = 1000
h = False
try:
while 1:
s.poll()
h = True
h = False
raise SystemExit
- Moutomation
20 Aug 2024 06:05 - 20 Aug 2024 06:06 #308192
by Moutomation
For example, if we can do this, there is always this file in the mnt folder. If there is no this file in the taglio folder, if we copy this file from the mnt folder to the taglio folder, my problem will be solved again.
for example:
import os
import time
import hal
import linuxcnc
import shutil
source1 = "/mnt/CutDocument.txt"
destination1 = "/mnt/taglio/CutDocument.txt"
if there is no CutDocument
shutil.copyfile(source1, destination1)
h.ready()
s = linuxcnc.stat()
pulse_length = 1000
for example:
import os
import time
import hal
import linuxcnc
import shutil
h.ready()
s = linuxcnc.stat()
pulse_length = 1000
Last edit: 20 Aug 2024 06:06 by Moutomation.
- Thank you received: 2176
20 Aug 2024 06:30 #308193
Replied by Aciera on topic gmoccapy pins
I'm not sure I understand which file needs to go where but you can check for file existance using 'os.path.exists(file)':
if os.path.exists(source1):
print("The file exists.")
else:
print("The file does not exis so we copy it from the mnt to the taglio folder")
The following user(s) said Thank You: Moutomation
- Moutomation
20 Aug 2024 07:44 #308195
by Moutomation
Great, just what I wanted, thank you very much for your support.
Moderators: newbynobi, HansU
Time to create page: 0.340 seconds
