Gmoccapy 3.5.1
1 year 3 months ago #331255 by HansU
Replied by HansU on topic Gmoccapy 3.5.1
I start the program with an external button.
Well, yes but what hal pin do you use to start the program?
I presume 'halui.program.run'
Probably. At least I could reproduce it this way.
1 year 3 months ago #331261 by Aciera
Replied by Aciera on topic Gmoccapy 3.5.1
The issue here is that using 'halui' in parallel to a gui is not really a very good idea at all. Many do it, myself included, to connect panel buttons. Gmoccapy is designed to use button rows aligned with the gui buttons but that is not always practical.
I wonder if it would make sense to have gmoccapy create its own dedicated pins like 'halui' so we would have more control over them.
1 year 3 months ago #331267 by besriworld
Replied by besriworld on topic Gmoccapy 3.5.1
Control panel connections :
net matrix_r2c2 matrix_kb.0.key.r2c2 => halui.spindle.0.stop
net matrix_r2c1 matrix_kb.0.key.r2c1 => halui.spindle.0.forward
net matrix_r2c3 matrix_kb.0.key.r2c3 => halui.spindle.0.reverse
1 year 3 months ago - 1 year 3 months ago #331295 by pippin88
Replied by pippin88 on topic Gmoccapy 3.5.1
Suggestion / request:
Overrides
When starting a program running (cycle start): user is prompted that an override (rapid, feed, or spindle) and asked whether they want to continue with override, or want to reset to 100%
I could imagine make an optional warn dialog with a settable limit. For all overrides? Feed, rapid and spindle?
Yes, something like attached.
Warning pop up if any override is on.
Last edit: 1 year 3 months ago by pippin88.
1 year 3 months ago #331559 by HansU
"Reset to 100%" would not work if you are using analog signals for the overrides.
So it will be only options for proceed and abort.
1 year 3 months ago #331561 by pippin88
Overrides are just set via physical up and down buttons, or via GUI in my setup.
New machine will sue encoders to have physical knob.
If easiest, a pop up warning that overrides are set, and buttons to cancel program, or proceed, would be very useful.
Moderators: newbynobi, HansU
