Gmoccapy 3.5.1
1 year 3 months ago #331231 by besriworld
Replied by besriworld on topic Gmoccapy 3.5.1
I use Match 3 on another machine and it has this functionality and I thought it was something standard. :)"You mean when the machine is already homed? "
 YES .
"But the spindle should resume at the same speed. Can you give an exmple to reproduce that?"
I will make a video.
"A bit unusual use case though, but I agree that should not abort the program."
Yes, I accidentally started the program from this menu and at one point I decided to go to the main page and the machine stopped. The program should simply not be started from this menu or it should not stop. I already know and I will not start the program in the editor. But maybe I will not be the first to find this bug. :)
1 year 3 months ago - 1 year 3 months ago #331234 by Aciera
Replied by Aciera on topic Gmoccapy 3.5.1
When you're in the G-code editor, it's possible to start the program execution, but if you exit the editor, the program stops .
How do you do that? Using halui?
Last edit: 1 year 3 months ago by Aciera.
1 year 3 months ago #331235 by besriworld
I start the program with an external button.
1 year 3 months ago #331239 by besriworld
This time, the spindle didn’t stop. However, when exiting the editor, the graphical interface shows that the program is not running
youtube.com/shorts/axVyF3tfrcw?si=d6pKXhjEwYUU1QWp
youtube.com/shorts/ay-Nz62fcPs?si=QHA_4l6xV2o7P6Ro
1 year 3 months ago #331243 by HansU
Replied by HansU on topic Gmoccapy 3.5.1
Suggestion / request:
Overrides
When starting a program running (cycle start): user is prompted that an override (rapid, feed, or spindle) and asked whether they want to continue with override, or want to reset to 100%
I could imagine make an optional warn dialog with a settable limit. For all overrides? Feed, rapid and spindle?
1 year 3 months ago - 1 year 3 months ago #331244 by Aciera
Well, yes but what hal pin do you use to start the program?
I presume 'halui.program.run'
Moderators: newbynobi, HansU
Time to create page: 0.066 seconds
